Lift kit
GlowBugTDI
Cambridge, MN
Otherwise ID parts sells "beef on a budget" lift
Nuje
Island near Vancouver
Th last comment sounds like AI, useless info at the least.
Totally.
If it sounds like it was written by a wanna-be-overachieving 6th-grader (who thinks a little too highly of their knowledge set, as in this case), it's probably Ai.
northern diesel
Northern BC
2006 mk4 TDI Jetta Wagon
A lift is a useful option when deciding you want the bottom of your vehicle to be higher from the ground than stock …
Just kidding guys 😂
Human here, I have a BEW with esp - and have been running metal nerds maybe 3” lift kit if I remember correctly - with no issues whatsoever.
im also knee deep in the beef on a budget suspension refresh - which is good cause one of both pairs of shocks when you push down stays stuck down. That must explain the slamming feeling I’d get with potholes.
( I’m waiting on an unusually slow delivery from roseland tech - for some bolts and upper strut mounts that I didn’t know I needed to replace)
but yeah the metal nerds I can vouch for with ESP :)
jmodge
Greenville, MI the winter water wonderland
More than I need, less than I want
Just kidding guys 😂
Good to know about the ESP, I was wondering about that.
kcunniff
Southwest Florida
2015 Audi Q5 Quattro
OP, I had installed Jetta Sportwagen springs in my '05 BEW for towing, and it did give a lift to the rear when not under a load. I suppose this option doesn't address the front end for you, but is an easy, effective way to lift the rear.
