All the other threads I've found are old and really just talk about one or two options at a time. In 5 years when this thread is old hopefully someone compiles a set of new options.
If some people could help me fill in the unknowns.
PD In-Tank Lift Pump.
Make: VW
Availability: IDParts BoraParts
Price: $200-230.
Pressure: ??
Flow: ??
Dry Lift: N/A
Type: Centrifugal
Flow on Failure: Yes(?)
Facet High Performance Gold-Flo
Make: Motor Components, LLC
Availability: NAPA, online vendors
Price: $85
Pressure: 1 - 8 psi
Flow: 20 - 45 GPH
Dry Lift: 12 - 24 inches
Type: Centrifugal
Flow on Failure: ??
Link: http://www.facet-purolator.com/gold-flo.php
Facet Cube
Price: $70-90
Pressure: 1 - 15 psi
Flow: 6 - 50 GPH
Dry Lift: 12 - 84 inches
Type: Centrifugal
Flow on Failure: ??
Link: http://www.facet-purolator.com/cube-fuel-pumps.php
Facet Posi-Flo
Price: $50-90
Pressure: 1.5 - 10 psi
Flow: 23 - 40 GPH
Dry Lift: 12 - 50 inches
Type: Centrifugal
Flow on Failure: ??
Link: http://www.facet-purolator.com/posi-flo-pumps.php
Kennedy Diesel Duramax lift pump
Availability: Kennedy Diesel
Price: $195
Pressure: 4 psi
Flow: ?
Type: Centrifugal
Flow on Failure: "Virtually unrestricted"
Link: http://www.kennedydiesel.com/detail.cfm?ID=399
Mr. Gasket Micro Fuel Pump
Availability: Mr. Gasket, online vendors.
Price: ~$60
Pressure: 4-7 psi
Flow: 35 GPH
Dry Lift: None (Install lower than the pump)
Flow on Failure: ??
Link: http://mr-gasket.com/air-and-fuel-systems/fuel-pumps/micro-electric-fuel-pump-diesel.html
Carter P4070
Price: $80
Pressure: 4-7 psi
Flow: 72 gph
Dry Lift: None
Type: Rotary Vane
Flow on Failure: ??
Link:
Walbro FRA/FRB/FRC/FRD
Price: ~$130-160
Pressure: 2.5-16
Flow: 10-50 gph
Dry Lift: 24-120 "
Flow on Failure: ??
Link: http://autoperformanceengineering.com/html/fr_pumps.html
Make: VW
Price: $200-230.
Pressure: ??
Flow: ??
Dry Lift: N/A
Type: Centrifugal
Price: $85
Pressure: 1 - 8 psi
Flow: 20 - 45 GPH
Type: Centrifugal
Flow on Failure: ??
Facet Cube
Price: $70-90
Flow: 6 - 50 GPH
Type: Centrifugal
Flow on Failure: ??
Facet Posi-Flo
Price: $50-90
Flow: 23 - 40 GPH
Type: Centrifugal
Flow on Failure: ??
Price: $195
Pressure: 4 psi
Flow: ?
Type: Centrifugal
Price: ~$60
Pressure: 4-7 psi
Flow: 35 GPH
Flow on Failure: ??
Carter P4070
Price: $80
Pressure: 4-7 psi
Flow: 72 gph
Dry Lift: None
Type: Rotary Vane
Flow on Failure: ??
Link:
Price: ~$130-160
Pressure: 2.5-16
Flow: 10-50 gph
Dry Lift: 24-120 "
Flow on Failure: ??
