sfierz
Hey guys, I just got done with changing out the oil cooler O-ring, oil stand gasket, CCV tube and a leaky oil pressure sensor, but it seems I may still have a pesky oil leak somewhere. I'm not sure if the is just residual oil caught up in the foam of the pan leaking out or if there is indeed an active leak. I have had the intermediate shaft and crank shaft seals changed, the valve cover gasket and cam seal replaced, and of course timing belt, water pump, and harmonic balancer replaced. I have checked connections at the turbo oil line and they don't seem to be leaking, so where could engine oil leak other than these? The clutch has been replaced and the rear main oil seal replaced as well. I suppose it is possible that some of these were not replaced correctly, but I know I bought quality German parts and had a trusted shop well-versed in VW and TDI's put these parts in. I'm just kind of at a loss as to where oil could still leak.
The oil cooler repair seems to have helped, but I guess I was expecting near zero oil leaks but maybe that is too much to ask on a 96 Passat TDI with 236k miles. I'm thinking when I get time I will go in and check some easy places like the valve cover gasket since this would be easy to R and R in case a seal might have gotten pinched on install. I don't know about the oil pan gasket, I suppose that could be a point of failure if it hasn't been replaced or if the clutch install disturbed it in some way.
Other than that, I am just grasping at straws here and need some help. I suppose time may tell since things may be "settling in" or residual oil may still be leaking off the engine pan. It was pretty soaked when I removed it for the oil cooler fix.
