Leedogg is back- with a passat this time- transaxle leak question.
Leedogg
Brewton, AL
Present: 05 Passat TDI Past: 06 Jetta TDI
I thought my 'new to me' 2005 TDI passat(109.200mi) had an oil leak. But upon further inspection- I realized that it is the seal on the left cv axle. I have yet to locate a tranmission dipstick on this thing. wondering if it might be getting low. I doesn't appear to leak when driving- judging by the cleanliness of the under side. But everytime I stop is leaves a small puddle. The shaft appears to 'bolt' together, like it has a yolk out of the transaxle. Are these seals hard to replace? any write up, or how to's?
I have searched autozone for the parts- but they don't even show the part available...
I have looked all over for a way to gauge or add transmission fluid. I don't see anything!
hysterwv
WV, OH, KY
Unfortunately there's no way to check fluid level other than pull the fill plug and even then there's a very specific procedure for checking trans fluid level.
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
suggest you buy the Bentley manual which will not only explain the procedure for stub axle seal replacement but also show transmission servicing as well. left side is very different from right, for example. it will be money well spent
Leedogg
Brewton, AL
I searched for bentley manuals...seems they are for gassers only for certian ons and the ones I saw that included TDI's were alot higher...anyone have a direct link?
thundershorts
west chester pa
unfortunately the bentley is about 100 bucks, but you might save making mistakes that would cost much more.
You know the differential has its own lube supply on that transmission seperate from the actual gearset, right? Are you leaking ATF or hypoid oil?
The paper Bentley does not have the TDI B5, but the transmission bits in this case are the same as the gas cars.
This is a ZF 5HP-19FL transmission, if that helps you find some online data. Sometimes the carrier bearings get the crap beat out of them from Chinese axles, and when this happens, the seals leak.
thundershorts
west chester pa
Confucius say:he who installs Chinese axles is Won Dum Fok
spiceredwagon
Edmonton
06 wagon
Mine has a leak in the same spot. VW vortex has a fix it article. Since mine has high km I decided to top it up once a month until something else breaks in the area. This site already has good tips on how to fill it, do a search.
Diagnosing the leak cost me a power steering hose. The fluid is the same color and sprays up onto the ps hose. I did the hose along with the chainectomy so it was easier to get at.
