freakwithracket
I'll jump in again to explain some things. Spoon has been accurate in everything he has said about the lights so far. The wiring on that strip has three wires. A + for the amber LEDs, a + for the white LEDs, and a ground. I tie them into the appropriate power sources and ground.
Those things are nylon cable clamps. They are a opaque white. The problem with the strips was one that got me for a few days. They come with these little clips that you can screw into whatever surface you want to mount them on, and then the strip is guided through those clips. Problem was that the clips use screws that were absurdly small. Given the interference of the lens and the small screw, it was impossible for me to get them screwed down. Then on top of that, the plastic on the headlight lens lip is very hard. It just was not going to happen.
So the next thougth was to put it down with some silicone adhesive or some other bonding substance. Well, given that we wanted the strip to curve up ward, it would naturally want to bend back, and it would have been impossible to get it to stay curved while an adhesive dried. That is to say nothing of the likelihood of it turning into a total ugly mess.
So I went to the hardware store and looked around and came across thos nylon cable clamps. I pretty much drilled holes in the bottom of the lens, rand the strip through the clamp, and then secured the clamp using a bolt through the bottom that just barely made it through the other side. Then I used some silicone adhesive sealant around the nuts along the bottom to prevent moisture from entering. It turned out great, because as spoon said, while they are slightly viable with the lights off, they are not visible with the lights on.
