Hornblower
I've done some searching but haven't found the details for doing what I have in mind. First off, my OEM headlight switch is only off-on. Rather than change that, what I want to do is install LED DRL's and wire them so they are always on anytime the engine is running. I had previously disabled the stock DRL's because I just don't appreciate the "cheezy" idea of using the regular low beams for DRL's. LED's would last much longer, run cooler, and use much less power than regular headlight bulbs so, to me, it's a matter of three things...where to mount the LED's, what LED bulbs to use, and where to make the electrical connection. I'm hoping someone else has already figured out how to do this and is willing to share that information. It would be much appreciated. --Ken B.
