OlyTDI
I’ve got a set of aluminum wheels on my Golf, a few of which leak air slowly around the valve stem seat. This started with one wheel as a really slow leak a number of years ago but has progressed and now it is happening on a second wheel.
The wheels are in great shape — no corrosion or finish deterioration. I can see really fine foam develop around where the valve stem seats in the wheel’s hole when I spray soapy water on them and then examine them 15 minutes or so later. The leaks are about 10 psi or so over a two week period. So I have to top the tires off regularly. I’m in need of new tires so I should address this prior to buying those.
I should note that every time I have stopped in at Discount Tire to have the tires rotated. I have mentioned the problem and they then replace the valve stems but to no improvement.
I’m wandering it there is a way to hone the holes in the wheels or perhaps spray a clear lacquer on them to help seal the stems(?). Or do I need new wheels? I could use the tire stop leak goop, I guess though I know the tire techs hate that stuff.
The wheels really are in otherwise great shape and I cannot see any corrosion. Though, admittedly, I haven’t taken the tires off and removed the stems to inspect the holes in detail.
Thoughts?
Thanks up front!
Thoughts?
Thanks up front!
