02 alh tdi
I have a 2002 tdi with the alh and a automatic transmission, today I was out having some fun with it today when I noticed a puddle of tranny oil under it, when I took a look underneath it is coming from in between the block and transmission from the little holes in the case. It only leaks while it’s running and it takes a few seconds to start leaking and leaks a pretty steady stream. Anybody have any idea where it’s coming from? Any ideas help, thank you
