Tankthecarman
Greetings! I’ve been chasing all of the leaks my MK4 Jetta has embraced. I solved the leak under the dash, addressed the clogged drain lines from the sunroof, but the gasket is cracked and not making a good seal. I’m planning to replace the sagging headliner, but think I should fix the gasket first. Any suggestions for finding a good quality replacement? Thanks in advance.
