Leaking Rear Washer Bulletin
Mass. Wine Guy
Ipswich, Massachusetts
2001 Golf GLS 5-speed, 2003 Jetta GLS wagon 5-speed, 2015 Golf S 6-speed manual
Did the tech bulletin VW issued years back about MK7’s leaking rear washer nozzle leak expire? Or could you still get it fixed for free?
Nuje
Island near Vancouver
If not, pretty good how-to-fix diy done up over at the vortex.
Nuje
And actually, from the sounds of that thread, and following the link, seems like it's not even a TSB, but rather a TT ("Tech Tip": # 92-14-04) the fix documented in the TT (part replacement from VW) doesn't seem to fix the issue either.
I'd be inclined to go the DIY route outlined in the Vortex thread.
740GLE
NH
i just wipe down the rear window each fill up.
I think the issue is in the the hot sun the fluid expands in the line and dribbles out, if i don't use the any washer fluid front or rear in a while it usually stops leaking until I use the fluid again.
for those 3 magical weeks in spring when its both black fly and mosquito season I swear i use more fluid than in the winter.
tdidieselbobny
Stafford,NY (WNY)
I replaced the nozzle itself once because I think I broke it when cleaning ice off rear window. I think it was a dribbler, I bought the whole light assembly and replaced it a few years ago. It just started leaking again a couple weeks ago :mad: :mad: :mad: . Guess I'll have to look at that permanent fix...
