That may very well help you find where your leak is, provided the leak is there and not upstream of the filter, like at the tank check valves.
Did you change the filter at all? How old is it? Who made it?
I have seen off-brand filters not seal properly on the B4's due to a bad o-ring. This is seen when you push down slightly on the Thermo-T while the car is running. If the bubbles go away or lessen, then it's a poor seal. I have known people to get by temporarily by applying some grease to the o-ring connection, which will help stop the air intrusion. The A4 fuel filter and the B4 are not interchangeable since the Thermo-T holes are different sizes and types, so you can't run the A4 filters unless you change the T as well, if you're thinking along those lines.
Your car may start hard if the QA is misaligned and the IQ is too high, like above 12. Ideally it should be 3-4 for stock injectors and 5-6 for larger injectors, adjusted for smoke of course.
I find it odd that the guy who says this: After Inj Pump is primed and flowing out the return - I cut up sections of a clean white sock and put them between the injection lines and injectors. Then crank on engine/starter to bleed the lines. The sock material will contain the fuel from spraying all over everything - and changes color to let you know when each one is bled.
also says this later on: Been drilled and grilled about never leave a pump open or exposed to any potential elements for any amount of time that is avoidable, by pro pump builders. Those guys consider a couple specks of dust or a few grains of pollen to be a potential nightmare. I consider the prevention less expensive than the cure. So i do my best.
Knowing the injectors are just, if not more, as particular to foreign object intrusion as the pump, I have to question why you'd think it was OK to possibly introduce a piece of fabric into the injectors. Wrapping a sock around it to reduce spray is one thing, but nothing should go between the injector hard line and the injector body, especially something like a sock.
The injector has a hole size of 184µm (microns) which is 0.007 inches (or 7 thousandths) and is much smaller than a cotton or nylon thread.
