gallaj01
- Joined
- Mar 25, 2008
- Location
- Madison, WI
- TDI
- 2002 Jetta Wagon TDI GLS, 2001 Jetta TDI GLS, 2017 Golf AllTrack
I was driving home from a weekend at the cabin in my 01 Jetta with 255K miles and 5 miles from home my coolant light came on. Usually a coolant light doesn't worry me too much on a high mileage car (thermostat housing, hard coolant pipe, various aging gaskets), but my experience is that when these sort of slow leaks occur the light/alarm only comes on once the car has stopped and the coolant level is steady. In this instance the light came on while traveling near 70mph after traveling over a road heave. I didn't see a bunch steam come out of the hood or a trail of coolant behind me, so I just drove the last couple miles home.
When I got home, I see that the coolant expansion tank was empty and noticed a steady drip from the belly pan. I put the car up on ramps pulled off the belly pan and started looking for the source of the leak. I check the usual suspects (tstat flange, hard coolant pipe, egr cooler) and none of them were leaking. I crawled under the car and could see coolant leaking from the bottom of the TB cover.
Popped off the upper TB cover and found this:
The inside was covered in coolant. I looked at the water pump and thought the sprocket might look slightly out of alignment, so I gently pried with a screwdriver: http://youtu.be/HxO2ejq4JOA
Looks like the water pump could have completely gone at any moment. I was so lucky it didn't completely go and take out the TB
My 01 Jetta TDI is due for its 3rd TB change in the next 5K miles. I had already ordered all the parts and was planning on due it the second weekend in August. Only trouble now is the garage, tools, and parts are all 250mi away. Looks like I should have done it sooner
So glad JasonTDI is only 15min away now that I live in Madison, WI. A big thank you to him for being available to tow my car to his shop and take care of the TB change this coming weekend!
