Leaking Clutch master cylinder???
Asbury030
Bradenton,Fl
13 Golf
It's leaking right under the clutch pedal on to my floor mat. I'm assuming it is a bad clutch master cylinder... so I ordered a new gasket and new cylinder. Going to hopefully have it fixed Sunday morning.
burn_your_money
North Bay, ON
99 Beetle, 96 B4V, 05 Passat wagon
You are correct. Mine just did that last month.
If you don't disconnect the clutch line at the slave, the master is self bleeding. Just slowly pump the pedal about 50 times and it will bleed the air out. No need to mess around with bleeders and 2 people.
