Derramax
- Joined
- Jul 13, 2013
- Location
- Bay Area, CA
- TDI
- 1998 Jetta TDI, 2005 Golf TDI, 1979 Rabbit 1.5D, 1964 Dodge D300 353N Detroit
I went to move m my wife's 15 Golf and the clutch pedal went and stayed on the floor. The Reservoir was low on fluid. I took out the airbox and battery to look for leaks in the clutch system and bleed it back to function. Got it back working and couldn't find any leaks in any of the clutch hydraulics and it was dry inside car. I suppose my next step is to check the brakes and lines at each wheel, one by one.
Question I have is: Anything else I should check to find where I am losing brake fluid? I'm going to monitor the fluid level to see just how fast the amount is going down in the reservoir and see if I have a slow leak or a significant one.
