03PlatinumTDI
Hello TDI experts. Got a little situation here. Car is a 2003 Jetta TDI.
The last time that I changed the timing belt (about 45K miles ago), I also replaced the thermostat. I mistakenly torqued (didn't check torque setting before) the two bolts that hold the plastic coolant pipe and thermostat to the block too tight. I knew that one day I would have a problem there and I now have a leak there.
What's the best route to remedy this? Should I just source some slightly larger bolts and torque them in? Or do it properly and tap out the holes and then use larger bolts?
I just ordered some replacement coolant, amongst other things from IDParts so I should be ready to take action this weekend.
Thank you for any help you can give. I'm sure I'm not the first person to do this.
Thanks!
Thanks!
