Leak down test
Dimitri16V
DE
01 Golf, 04 Golf
400 psi ? I would have to lock the engine to keep it from turning
hughesjasonk
New York
2002 Jetta MK4;
the piston is going to be in the up position with the valves closed.
It isn't going to be 400 psi. probably around 100psi but i have to look at the book to be sure.
a leak down test is not the same as a compression test.
RIP TDI
Santa Barbara, CA
'15 GSW SE 6MT, '01 Golf 5MT, '97 Passat sedan, '96 Passat variant
Leak-down testing is usually done at TDC on compression.
If using a dedicated-use leak-down gauge (i.e., graduated in percentage), the gauge manufacturer usually specifies the line pressure at which the gauge is calibrated to read most accurately.
