KrashDH
Well I've been after this the last couple days and decided to stop by the local Pick-n-Pull to see if there were any worthwhile parts. There were about 6 Jettas to choose from so that was a good thing.
The Golf GLI came with these vents, but none were lighted. I didn't care which version came off the Jetta since none of mine on the Golf are lit anyway. There's enough lit up buttons on the center and driver side vent area to fumble my way around, and my passenger, well, they're on their own.
Most have removed their vents but I took some photos just so everything is in a condensed thread.
So obviously you will need the driver, center, and passenger vents. If you purchase or go pull your parts, if you're a Golf, you will need a couple pieces for the driver side vent as well as the center vent. I'll call these extra pieces the "cradles" for the vent. They get bolted in the dashboard first, then the vent snaps or gets bolted into them. Unlike the swivel vents (OEM Golf) where you remove the swivel part then un-bolt the rest of the vent housing.
The passenger side, only the vent is needed, there is no cradle.
Here's what I'm talking about, these are the center vents. On the left is the swivel style, on the right is the lay flat style:
This image is just the lay flat, with the cradle behind it:
I started with the easiest, the passenger.
You're going to wedge your thin object between the vent housing and the dash on the passenger side of the vent. It should pop out. Then you can wedge you thin object on the passenger side, and the other side should pop out. Easy.
Those of us with the non lighted version, if you buy the lighted version, you will need to punch out this square (I used a flathead screwdriver) so you can fish the wires back through there:
After that, feed your new lay-flat vent wire through your new hole, and with even pressure, press your vent in. It will lock in with tabs:
I moved on to the driver side after that. There is a lot of documentation on how to remove the headlight switch, but the non-parking light crew (me currently) needs to push the switch in, turn clockwise, and it will stop between the off and on setting:
That will expose the lower torx head screw behind the switch. Remove it.
Whatever thin object you have, get it behind the flange of the dimmer switch. It will pop out. Give yourself enough slack to remove the plugs from both the switches.
Next, remove the vent. You can see where I placed my plastic trim tool:
Popping the swivel piece out will expose the upper torx head bolt. Remove that now. Everything should just be a-danglin':
8 photos, onto next post
