PDJetta
- Joined
- Nov 6, 2003
- Location
- Northern Virginia
- TDI
- '04 Jetta GLS TDI Pumpe Duce Platinum Grey w/ Leather
Since I am stumped about this one, I thought I would ask the experts on this list. Here is the history of the problem:
This is my mother's Honda 4-stroke self-propelled "push" mower, about 6 years old. Last year my son was mowing her grass with it and tipped it up on its side to clear out some grass. The mower failed to start after that. I took a look and determined it was flooding, since gas was being spit out of the muffler when pull-starting it (could also get it to run by turning the fuel valve off to run it dry and then crack the valve a hair), but turn the valve on, it flooded and stopped) Ah, stuck float, I thought. I removed the carburettor and opened it up to check the float and float valve. Everything looked OK. Still flodded. Put a new carburettor on it (only $16!). Same thing--flooded. Then I discovered the flooding was because of the oil soaked air filter element (from oil flowing through the breather pipe when my son tipped it over, coating the filter and plugging it solid so air would not go through it). Replaced the air filter and it would run, but after warming up, under load would loose power, backfire through the carb and finally cut off. I put on the old carb. Same thing. Would not run warm under load. I then replaced the carburettor mounting gaskets (I reused the gaskets when I replaced the carb). No change. Took it to the lawnmower shop. They replaced the carburettor mounting (intake) gaskets again and said that was the problem. The mower then worked for a couple of weeks and then began doing the same thing.
I do believe it is a fuel problem, not an ignition problem, because when it begins cutting out, if I engage the choke, it will come back to life and run (although too rich to use). I can modulate the choke and it kind of runs. I also checked for a kinked fuel line from the tank and also looked for a fuel filter, but I do not see one. I would suspect a plugged carb jet, but with two different carburettors it does the same thing. Any ideas? I have spent hours working on this and am at a total loss as to what is going on.
Is there a sure fire way to narrow it down to a fuel or ignition issue?
Thanks.
--Nate
Thanks.
--Nate
