Larger wheels and tires
MartyPongo
Costa Mesa, CA
13 JSW GTD 06 Jetta GTD Sedan and 11 JSW
Hi all,
I have two TDI Sportwagens and a TDI sedan. I put 17" wheels from a 2011 Audi A5 on the sedan with 235/45-17 tires and they dramatically improved handling with absolutely no rubbing. I'm interested in upgrading the wheels/tires on my wagons next and would like to use similar 17" wheels. Does anybody have any experience with larger tires (good or bad)?
PRY4SNO
Edmonton, AB
2013 Touareg Execline
That's likely got more to do with you adding an inch per corner of rubber.
You'll also reduce the fuel mileage while doing so, if that's a concern to you.
What kind of driving do you typically do? There are a number of tiers of tires that are worth considering regardless of budget to achieve improved handling characteristics.
mikerob97
Wake Forest, NC
2014 Jetta Sportwagen
I am running the following combination:
Borbet Type Y
Size: 17x7.5 (Factory Diameter)
Finish: Crystal Silver
Offset: +45mm
Michelin Pilot Sport All Season 4
225/50 x17"
This combination works well for me, a tad softer that the 225/45s that came with the car.
