surf_city
Just wondering if it is possible to have a larger fuel tank. I have one on my ranger that is 62 gallons but don't know if I could fit a 25-30 gallon tank in there. Thanks for the help in advance this will be for a 2010 JSW TDI.
Same here, but I'm young now and am never getting old.How big is your bladder anyway - how many hours can you go without having to drain your "tank"? I'm getting old - I have a hard time making it as far as my fuel tank will go as it is.
Try reading this: http://forums.tdiclub.com/showthread.php?t=305520
Have Fun!
Don
Not really. Fuel tanks now a days are molded to the chassis of the car. Fitting an auxiliary tank of appreciable capacity is an impossibility.Just wondering if it is possible to have a larger fuel tank. I have one on my ranger that is 62 gallons but don't know if I could fit a 25-30 gallon tank in there. Thanks for the help in advance this will be for a 2010 JSW TDI.
I thought the spare tire tanks used in grease cars can hold up to 10-14gal? the hardest part would be how you fill it and how it plumbs to the OEM tank.Not really. Fuel tanks now a days are molded to the chassis of the car. Fitting an auxiliary tank of appreciable capacity is an impossibility.
there is room for 5-6 gallons if you remove the spare tire however you'd be adding a fuel tank to the INSIDE of the car, meaning bad things can happen if you get rear ended or in a collision..
My point is your adding fuel to the inside of the vehicle. Diesel isn't as volatile as gasoline, but under certain conditions that can be satisfied in a severe collision diesel can ignite. But in all seriousness, who can sit on their ass for 600+ miles (8-10 hours)?.I thought the spare tire tanks used in grease cars can hold up to 10-14gal? the hardest part would be how you fill it and how it plumbs to the OEM tank.
I'd love to add another 10gal capacity, even thought i don't need to run through that much gas in one sitting, it'd just reduce the number of fill ups.
You mean except MEOWGUY who clocks about 720 per week.But who here regularly eats up 600 miles a week?
Ah I do, often as a matter of fact. I think my 17.5 gallon tank on my Passat is just fine. Some weeks, I do only 300 and then there are 700 mile weeks.But who here regularly eats up 600 miles a week?
Straight from my Excel program, which is what I use to log all my fuel and mileage data, going back many years when I bought the car. Over the lifetime I average:But who here regularly eats up 600 miles a week?
You do know you can send SMS text messages to Fuelly.com right from the pump.Straight from my Excel program, which is what I use to log all my fuel and mileage data, going back many years when I bought the car. Over the lifetime I average:
I love fuelly, but I still use an excel sheet so I can do other crazy things with the graphs and such...You do know you can send SMS text messages to Fuelly.com right from the pump.![]()
Not really.....It'd just reduce the time i spent standing infront of the pumps.
Not really.....
Say you spend 5 minutes per week filling up your 14.5 gallon tank. And say you do this 4 times per month. That is 20 minutes.
But, If you double your fuel capacity, it will now take about 10 minutes to fill, but will occur half as often.
So you are not really cutting any time out of filling. You are theoretically only saving the time of driving up to the pump (assuming your normal filling station is in your normal driving route) which would only equate to maybe 10 seconds per subsequent visit to the filling station.
BUT, your vehicle would have to haul MORE weight when your larger tank is full which may equate to less fuel economy.
Yeah, and hanging drywall is pretty fast too. But that doesn't include mud, sanding, painting, cleaning up. If I hired you for a job it would be bid pricing, definitely won't be based on a time estimate!!Not really.....
