benjamin2614
Hi! How about I have a Jetta mk6 2011 TDI, the big fan turns on seconds after opening the key ... I found that the sensor that is in the hose behind the fans is cut, I attached the cables and that problem is corrected but the air conditioning stops cooling: / Could you help me with this problem and / or send me a photo or description of the correct polarity of said sensor cables (yellow and brown) since they were torn from the base of the connector. Another question, when should the small fan turn on? An apology, I am using a translator
