pahanorlando
Hello all. I am working on my brother's Jetta TDI. According to him, he was driving and heard some bang from engine area. Approximately after that, he says car is very slow on acceleration. I did some research and believe mostly issue happens because of MAF sensor or air leak somewhere and also possibly EGR.
So here is what I did, I drove it around, no issues on idle at all. Only when I accelerate, gas pedal to the floor, it accelerates slowly. I also observed a black smoke coming from exhaust, although not always the case. I then parked the car and revewed the engine, highest it goes to is approximately 4000 rpm. Check engine light is on, but for whatever reason, my OBD machine does not sync.
I removed air filter and discovered it to be dirty (appear to be black sand in air filter). I cleaned the filter. I also observed one opening in air box (under air filter) to be unplugged, the one that is closer to firewall. I plugged it back in and secured with zip tie. I also disconnected MAF sensor and there was no difference at all with engine performance.
Please let me know what else I can check. Thanks
