Lack of power after a remap
Busternaut
Bulgaria
Golf Mk 4 ASZ
Hello everyone, I own a mk 4 tdi 131 hp PD. The car has a FMIC and a 1752vb hybrid. It has been remapped and makes 1.8 bars of boost however the performance is very underwhelming. I suspect that the fuel is not enough but the mapper tells me that this is the maximum fuel he can do. I only know that it is 75mg. but as far as I have read there are other factors such as duration? Is there a way I can check with vag com and post the results here so you can confirm my suspicion of not enough fuel? The car doesn't smoke at all, even if I floor it at very low rpm to intentionally make it smoke. I don't want smoke it is just really odd to me and confirms my theory.
Busternaut
Bulgaria
Golf Mk 4 ASZ
Log IQ with VCDS and see if it ever hits the 75mg/stroke value. There a several limiters that may restrict the max IQ and they all must be adjusted during a tune, perhaps he forgot something? 75mg/stroke at 4000rpm should be over 200hp, probably more fuel than that turbo can provide sufficient air for.
Hello, I have logged the charge pressure and the IQ. However it doesn't show more than 70mg, but the mapper told me that it is actually 75mg and the program just doesn't show it. The log shows the car achieves the boost required and it shows 70mg. This is under "max IQ" if it is not the correct place to look let me know.
So on paper everything looks fine but the car is sluggish, nowhere near 200hp.
One thing that is important and I forgot to mention is that the car was remapped with a 2.5bar map sensor (it was a mistake, the sensor came with the fmic and the guy tld me it was 3bar.) Right after the remap the car would smoke a little under full acceleration. I then thought about that sensor, removed it and saw it was actually 2.5bar. I then swapped it with the original 3bar and the car stopped smoking at all. Still sluggish though. I told this to my mapper and he said that it couldn't be the reason and everything should work fine. It is really suspicious to me the whole wrong sensor situation.
Busternaut
Bulgaria
Golf Mk 4 ASZ
Here is a picture of the log results. I am new to the forum and couldn't find a way to upload the log file itself.
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
Check this out.... you might like it
tdi_my live
Germany
Skoda Fabia
You can log block 04. There are seen SOI and duration. Duration you can recalculat to mg/h IQ.
Busternaut
Bulgaria
Golf Mk 4 ASZ
So this confirms that everything should really be fine on paper? The boost is there, the fuel is there but where is the power?
Mozambiquer
Versailles Missouri
Why is the actual maf so low?
Mozambiquer
Versailles Missouri
Busternaut
Bulgaria
Golf Mk 4 ASZ
Ok. I thought that normally when it was turned off it would have a default value like 850.
I don't know. I don't have so much knowledge on the whole remapping topic, everything I know is from reading on the forums for a week to try and solve my problem.. :/
Mozambiquer
Versailles Missouri
Busternaut
Bulgaria
Golf Mk 4 ASZ
I'm wondering if the tuner didn't correctly disable the maf sensor. Is the maf unplugged and removed, or plugged in?
It is currently plugged in. I tried to unplug it and test the car but it was the same. I could try again?
Is it possible to be a boost leak? Even though both my boost gauge and vcds show that I am reaching full boost.
Woudn't the car smoke alot if there is a boost leak? Or it will just limit the fuel? But then again it shows actual IQ is the same as requested.
Possibly a vacuum leak? I don't know what to think anymore.
tdi_my live
Germany
Skoda Fabia
Here is a log from block 015: https://log.tunezilla.com/s/8HI1cLSF
I noticed that the car keeps throwing a MAF error code even though the MAF is disabled. Is that normal or?
What did you expect to actually get a different IQ value? The information comes from the ECU and not from a sensor that measures the actual amount. Since the diagnosis has not been expanded, you will not see a value higher than 70.
tdi_my live
Germany
Skoda Fabia
Why was the MAF trying to deactivate. You don't need that up to a loose 1700mg air mass. If it starts to reach the maximum voltage then you have to switch over to MAP based and deactivate the LMM, but correctly without an error message. And beforehand you can increase the maximum voltage and create some tolerance for it.
tdi_my live
Germany
Skoda Fabia
Take a look at the boost pressure curve. The turbocharger is supposed to bring high boost pressure early on, and it doesn't do it. Then at 2600rpm skin over it, the VNT counteracts and opens. Then closed again. What do you mean, what does that decrease in performance and dynamics if the N75 control does not fit well. Your remapper has to go back to this.
