RockiesJetta
Seems like a reasonable choice to not allow it. Wouldn't you also need a key that would unlock the ignition and turn it to ON? I guess that could be anything since it doesn't have to be a RFID key just to do that. So just punch the column I suppose.While writing to ME7.5 ECU EEPROM is technically possible (just as KW1281test can do that with the EDC15 ECU), rational I have seen on nefarious motorsport forums is that the me7_95040_v1.31 program developer intentionally omitted this capability from public release since that would enable a car thief with a laptop an easy way to turn off ECU immobilizer and steal the car. I went the route of using a bench harness, opening the ECU security case and shorting pin to trigger boot mode when I wanted to re-write the EEPROM on a spare junkyard ECU to work on my IMMO 3 audi A4.
I already had rework tools, hot air, soldering iron, microscope, EEPROM programmer so it was the high speed, low drag approach I knew I could do that didn't require sourcing more stuff is all. They key was just knowing *what* addresses needed to be edited, e.g. the Nefmoto treasure trove.
I might go down the bench harness and spare ECU route at some point, I'd like to clean up the cluster and ECU. I have the flashing Immo light and a few stored DTCs now, which will irritate me, I just know it.
