2003_unicorns
Thank you.I believe you need kw1281test for that.
It looks like kw1281test doesn't fully unlock 3U0920942D clusters for full EEPROM read. If you have access to an EEPROM programmer (e.g. like this one) I can tell you how to change a few bytes that will unlock it for use with kw1281test.Hello, tryed to read eeprom from 3U0920942D cluster.
It is amazing that it can read Crypted cluster! However is it possible to read all data including keys, milleage and matching to engine?
There are addresses 50-5f, 70 to 14f not read from cluster.
What can I do to read data in full? Match one key to cluster?
Yes, I have ezp programmer and can read eeprom directly from chip, decryt it and modify as needed. Should I make cluster as New (change 060606 to 040404)? Or something other need to be updated?It looks like kw1281test doesn't fully unlock 3U0920942D clusters for full EEPROM read. If you have access to an EEPROM programmer (e.g. like this one) I can tell you how to change a few bytes that will unlock it for use with kw1281test.
No need to decrypt it. Read the entire EEPROM and email it to me (contact info here: https://bitfab.com/Contact) and then I can tell you how to modify it.Yes, I have ezp programmer and can read eeprom directly from chip, decryt it and modify as needed. Should I make cluster as New (change 060606 to 040404)? Or something other need to be updated?
https://github.com/gmenounos/kw1281test/issues/54#issuecomment-1903305187How can i use the tool to remove the immobilizer on my 2002?
Yes, bit you may need to replace "com2" with whatever com port your KKL cable is using. Also make sure to download the newest version: https://github.com/gmenounos/kw1281test/releasesAm I just going to command prompt, changing directory to file location, and using this command: .\kw1281test.exe com2 9600 1 WriteEdc15Eeprom 0x1B0 0x60 0x1DE 0x60 ?
What kind of cable are you using? If it's a RossTech cable then it needs to be one of the older ones that support VCP drivers and it needs to be set to "dumb mode" (e.g. uncheck "Boot in Intelligent Mode" in VCDS settings, save settings and unplug/replug cable before using kw1281test).Ok tried it this morning and am getting this:
The operation has timed out.
Caught: System.InvalidOperationException Controller did not wake up.
And don't delete the EDC15 backup file that was created in case you want to turn the immobilizer back on.That was it! Help is much appreciated! I am taking notes this time so I can remember the necessary steps. Immobilizer is off and all of my keys work!!
Checked as you have advised - cluster read in full! Thanks a lot.No need to decrypt it. Read the entire EEPROM and email it to me (contact info here: https://bitfab.com/Contact) and then I can tell you how to modify it.
If your 2dr Golf is the bargain-basement trim level (manual windows and mirrors typically signify that).....the CCM in those cars is not the typical 1C0***, but rather, some 1J0 thing that doesn't have the bits and bytes in the same places. I haven't been able to figure out how to get the "hatch lock status matches door lock status" that you've done on the wagon to work on one of these cars; granted, my sample size is exactly two, so....haven't spent massive resources trying to figure it out either.TLDR, Sorry. I successfully used this to get/keep my hatch open with the door switch on my 03 Jetta Wagon. Do I need to use this software on my 03 door Golf to do the same thing or can that be accomplished via VCDS? I like to go as far as I can with VCDS and then use this.
Thanks!!
Let me know if you need me to share what worked for me on the wagon. There is one odd and terrible cavaet though. If I open and close the hatch with it running it locks all of the doors.If your 2dr Golf is the bargain-basement trim level (manual windows and mirrors typically signify that).....the CCM in those cars is not the typical 1C0***, but rather, some 1J0 thing that doesn't have the bits and bytes in the same places. I haven't been able to figure out how to get the "hatch lock status matches door lock status" that you've done on the wagon to work on one of these cars; granted, my sample size is exactly two, so....haven't spent massive resources trying to figure it out either.
In that case it didn't workLet me know if you need me to share what worked for me on the wagon. There is one odd and terrible cavaet though. If I open and close the hatch with it running it locks all of the doors.
If I manage to obtain the SKC through other means...will I be able to use kw1281test to adapt new keys? Following the directions laid out in post #1264? Even if kw1281test won't pull my SKC?It works with most but there are a few that do not. I should make a list.
Yeah, it should be able to do that. But since you have an Audi, the adaptation channel might be different. You'll have to research. Whatever channel you'd use in VCDS would be the same that you'd use in kw1281test.If I manage to obtain the SKC through other means...will I be able to use kw1281test to adapt new keys? Following the directions laid out in post #1264? Even if kw1281test won't pull my SKC?
I attempted adaptation save after getting my skc....it did not work...now my immobilizer light is blinking ... and all three keys start the car....fault code when scanned showsYeah, it should be able to do that. But since you have an Audi, the adaptation channel might be different. You'll have to research. Whatever channel you'd use in VCDS would be the same that you'd use in kw1281test.
I think you'd be better off asking about adapting keys in an Audi forum. I don't know much about them and how they differ from MKIV VWs.I attempted adaptation save after getting my skc....it did not work...now my immobilizer light is blinking ... and all three keys start the car....fault code when scanned shows
01179 - 35-00
Will the command Findlogins check if the SKC I pulled is incorrect/correct? ((Vcds allowed me to login with the SKC I had but I'm only using the shareware version and so I couldn't use it to adapt the new keys) it showed channel 21 so that's what I used)
Will AdaptationRead or AdaptationTest display how many keys are paired? How are these commands used and to what end?
The car is drivable right now... I'm assuming some how I shut off the immobilizer.
Alright thankyou.Sorry, but I don't know anything about Audis.
Yes, it should allow you to pull the SKC from either cluster, but you'll still need to figure out what's wrong with your gauges. kw1281test has generally worked with Marelli Beetle clusters though there are a few Marelli Audi clusters that aren't supported.Hello and thank you for providing what looks like the SKC solution I'm looking for.
My 03 beetle came (recent purchase) with a replaced inst. cluster (also received what I was told is the original cluster) and neither one has gauge functions ( the odometer works on both) when installed. I found this Ross Tech video on swapping clusters and hope to use my VCDS to get the replaced cluster to work. - ECM & cluster swapping
Will kw1281test program help me find the SKC with the replaced cluster?
I see that beetle clusters were made by Magneti Marelli, does that affect using this program?
One last ?, the link for the cable in the first post of this thread goes to a cable that's not available on Amazon, will this one work? - Amazon KKL cable
Thank you gmenounos for your reply.Yes, it should allow you to pull the SKC from either cluster, but you'll still need to figure out what's wrong with your gauges. kw1281test has generally worked with Marelli Beetle clusters though there are a few Marelli Audi clusters that aren't supported.
I think that Amazon FT232RL-based cable should work fine and will be supported on more computers than the CH341A cables.
As far as I know, matching the cluster to the car is not necessary for the gauges to work. And, yes, if the ECU has the immobilizer deleted then the car will start even if the cluster isn't matched to the ECU (but the cluster will display an immobilizer warning light).Thank you gmenounos for your reply.
My understanding was that the gauges don't work because the cluster is not matched to the car/ECU ?
The ECU has had the immobilizer "deleted", this is what is allowing the car to run and the key to work, would this be correct?
Thanks again for your help.As far as I know, matching the cluster to the car is not necessary for the gauges to work. And, yes, if the ECU has the immobilizer deleted then the car will start even if the cluster isn't matched to the ECU (but the cluster will display an immobilizer warning light).
