kw1281test: A Free VDS-Pro / VagTacho Alternative
AndradeArt
Brazil
VW Polo 06/07
Here is a modified dump for your new cluster that should unlock it permanently and allow you to use kw1281test to modify the EEPROM. If that works, you'll be able to easily change the speed sensor data as well as any other data in the EEPROM without needing to remove the cluster from the car.
I redid the cluster and ecu combination and configured the keys. I tried to read the address "0x13A" (Odometer) and the program was unable to read it. The address "0x65" (SpeedSensor) was even able to read, but it is not writing a new value.
Version 0.98.0-beta (https://github.com/gmenounos/kw1281test/releases)
Args: COM2 10400 17 ReadEeprom 0x13A
OSVersion: Microsoft Windows NT 10.0.22621.0
.NET Version: 8.0.6
Culture: pt-BR
Opening serial port COM2
Sending wakeup message
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
ECU: 6QE920827C KOMBIINSTRUMENT VDO V06
Software Coding 00541, Workshop Code: 00000
Sending Custom "Read Software Version" blocks
Sending Custom "Unlock Additional Commands" block
00: VQMJ09HH $10 $05
01: $90 $28
02: $17 $02 $0A $0A $31 $02
03: PQ24_9HL SQ200 Maske
Sending Custom "Unlock partial EEPROM read" block
Unknown cluster software version. EEPROM access will likely fail.
Sending Custom "Get Access Level" block
Access level is 7.
Cluster is unlocked for ROM/EEPROM access. Skipping Seed/Key login.
Sending ReadEeprom block (Address: $013A, Count: $01)
EEPROM read failed
Sending EndCommunication block
Args: COM2 10400 17 WriteEeprom 0x65 0x86
.NET Version: 8.0.6
Culture: pt-BR
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
01: $90 $28
Access level is 7.
Sending WriteEeprom block (Address: $0065, Values: $86
Received "Write EEPROM Response" block: 01 00 65 79
WriteEepromResponseBlock body does not match WriteEepromBlock
Args: COM2 10400 17 ReadEeprom 0x65
.NET Version: 8.0.6
Culture: pt-BR
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
01: $90 $28
Access level is 7.
Sending ReadEeprom block (Address: $0065, Count: $01)
Received "Read EEPROM Response" block: 87
Address 101 ($0065): Value 135 ($87)
gmenounos
Watertown, MA, USA
'99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion), Non-TDI: '23 Tesla Model 3 AWD
Same issue as the weird one I had earlier, on first attempt the dump command and even GetSKC resulted in a timeout, after working previously.
After restarting cmd, GetSKC was successful, but the new command results in a timeout… the program is installed on the desktop, and I do have to set the working directory in each instance of opening cmd. This timeout is also usually the same error I get when messing around with AdaptationTest and AdapttionRead commands too, so maybe it is something to do with how I have installed the program?
Does VCDS-Lite work reliably and consistently with your generic cable to connect to the cluster and ECU? If it gives timeouts and sometimes requires moving the cable to a different port, then it might be an issue with your cable or driver.
gmenounos
Watertown, MA, USA
Ok, can you see if you can dump part of the ROM? That will hopefully help me figure out how to get the EEPROM read/write to work on your cluster.
The dump will take a number of minutes to run (about 16 times as long as it takes to dump the 2K EEPROM)
kw1281test.exe COM2 10400 17 DumpMem 0x28000 0x8000
AndradeArt
Brazil
VW Polo 06/07
At the end of the program execution, it presented "expected error": (I executed the command 3 times, and each time the reading stopped in a different block)
Args: COM3 10400 17 DumpMem 0x28000 0x8000
.NET Version: 8.0.6
Culture: pt-BR
Opening serial port COM3
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Software Coding 04541, Workshop Code: 00000
Access level is 7.
Cluster is unlocked for memory access. Skipping Seed/Key login.
Saving memory dump to cluster_mem_$028000.bin
Sending Custom "Read Memory" block (Address: $028000, Count: $0F)
Sending Custom "Read Memory" block (Address: $02800F, Count: $0F)
Sending Custom "Read Memory" block (Address: $02801E, Count: $0F)
Sending Custom "Read Memory" block (Address: $02802D, Count: $0F)
Sending Custom "Read Memory" block (Address: $02803C, Count: $0F)
Sending Custom "Read Memory" block (Address: $02804B, Count: $0F)
Sending Custom "Read Memory" block (Address: $02805A, Count: $0F)
Sending Custom "Read Memory" block (Address: $028069, Count: $0F)
Sending Custom "Read Memory" block (Address: $028078, Count: $0F)
Sending Custom "Read Memory" block (Address: $028087, Count: $0F)
Sending Custom "Read Memory" block (Address: $028096, Count: $0F)
Sending Custom "Read Memory" block (Address: $0280A5, Count: $0F)
Sending Custom "Read Memory" block (Address: $0280B4, Count: $0F)
Sending Custom "Read Memory" block (Address: $0280C3, Count: $0F)
Sending Custom "Read Memory" block (Address: $0280D2, Count: $0F)
Sending Custom "Read Memory" block (Address: $0280E1, Count: $0F)
Sending Custom "Read Memory" block (Address: $0280F0, Count: $0F)
Sending Custom "Read Memory" block (Address: $0280FF, Count: $0F)
Sending Custom "Read Memory" block (Address: $02810E, Count: $0F)
Sending Custom "Read Memory" block (Address: $02811D, Count: $0F)
Sending Custom "Read Memory" block (Address: $02812C, Count: $0F)
Sending Custom "Read Memory" block (Address: $02813B, Count: $0F)
Sending Custom "Read Memory" block (Address: $02814A, Count: $0F)
Sending Custom "Read Memory" block (Address: $028159, Count: $0F)
Sending Custom "Read Memory" block (Address: $028168, Count: $0F)
Sending Custom "Read Memory" block (Address: $028177, Count: $0F)
Sending Custom "Read Memory" block (Address: $028186, Count: $0F)
Sending Custom "Read Memory" block (Address: $028195, Count: $0F)
Sending Custom "Read Memory" block (Address: $0281A4, Count: $0F)
Sending Custom "Read Memory" block (Address: $0281B3, Count: $0F)
Sending Custom "Read Memory" block (Address: $0281C2, Count: $0F)
Sending Custom "Read Memory" block (Address: $0281D1, Count: $0F)
Sending Custom "Read Memory" block (Address: $0281E0, Count: $0F)
Sending Custom "Read Memory" block (Address: $0281EF, Count: $0F)
Sending Custom "Read Memory" block (Address: $0281FE, Count: $0F)
Sending Custom "Read Memory" block (Address: $02820D, Count: $0F)
Sending Custom "Read Memory" block (Address: $02821C, Count: $0F)
Sending Custom "Read Memory" block (Address: $02822B, Count: $0F)
Sending Custom "Read Memory" block (Address: $02823A, Count: $0F)
Sending Custom "Read Memory" block (Address: $028249, Count: $0F)
Sending Custom "Read Memory" block (Address: $028258, Count: $0F)
Sending Custom "Read Memory" block (Address: $028267, Count: $0F)
Sending Custom "Read Memory" block (Address: $028276, Count: $0F)
Sending Custom "Read Memory" block (Address: $028285, Count: $0F)
Sending Custom "Read Memory" block (Address: $028294, Count: $0F)
Sending Custom "Read Memory" block (Address: $0282A3, Count: $0F)
Sending Custom "Read Memory" block (Address: $0282B2, Count: $0F)
Sending Custom "Read Memory" block (Address: $0282C1, Count: $0F)
Sending Custom "Read Memory" block (Address: $0282D0, Count: $0F)
Sending Custom "Read Memory" block (Address: $0282DF, Count: $0F)
Sending Custom "Read Memory" block (Address: $0282EE, Count: $0F)
Sending Custom "Read Memory" block (Address: $0282FD, Count: $0F)
Sending Custom "Read Memory" block (Address: $02830C, Count: $0F)
Sending Custom "Read Memory" block (Address: $02831B, Count: $0F)
Sending Custom "Read Memory" block (Address: $02832A, Count: $0F)
Sending Custom "Read Memory" block (Address: $028339, Count: $0F)
Sending Custom "Read Memory" block (Address: $028348, Count: $0F)
Sending Custom "Read Memory" block (Address: $028357, Count: $0F)
Sending Custom "Read Memory" block (Address: $028366, Count: $0F)
Sending Custom "Read Memory" block (Address: $028375, Count: $0F)
Sending Custom "Read Memory" block (Address: $028384, Count: $0F)
Sending Custom "Read Memory" block (Address: $028393, Count: $0F)
Sending Custom "Read Memory" block (Address: $0283A2, Count: $0F)
Sending Custom "Read Memory" block (Address: $0283B1, Count: $0F)
Sending Custom "Read Memory" block (Address: $0283C0, Count: $0F)
Sending Custom "Read Memory" block (Address: $0283CF, Count: $0F)
Sending Custom "Read Memory" block (Address: $0283DE, Count: $0F)
Sending Custom "Read Memory" block (Address: $0283ED, Count: $0F)
Sending Custom "Read Memory" block (Address: $0283FC, Count: $0F)
Sending Custom "Read Memory" block (Address: $02840B, Count: $0F)
Sending Custom "Read Memory" block (Address: $02841A, Count: $0F)
Sending Custom "Read Memory" block (Address: $028429, Count: $0F)
Sending Custom "Read Memory" block (Address: $028438, Count: $0F)
Sending Custom "Read Memory" block (Address: $028447, Count: $0F)
Sending Custom "Read Memory" block (Address: $028456, Count: $0F)
Sending Custom "Read Memory" block (Address: $028465, Count: $0F)
Sending Custom "Read Memory" block (Address: $028474, Count: $0F)
Sending Custom "Read Memory" block (Address: $028483, Count: $0F)
Sending Custom "Read Memory" block (Address: $028492, Count: $0F)
Sending Custom "Read Memory" block (Address: $0284A1, Count: $0F)
Sending Custom "Read Memory" block (Address: $0284B0, Count: $0F)
Sending Custom "Read Memory" block (Address: $0284BF, Count: $0F)
Sending Custom "Read Memory" block (Address: $0284CE, Count: $0F)
Sending Custom "Read Memory" block (Address: $0284DD, Count: $0F)
Sending Custom "Read Memory" block (Address: $0284EC, Count: $0F)
Sending Custom "Read Memory" block (Address: $0284FB, Count: $0F)
Sending Custom "Read Memory" block (Address: $02850A, Count: $0F)
Sending Custom "Read Memory" block (Address: $028519, Count: $0F)
Sending Custom "Read Memory" block (Address: $028528, Count: $0F)
Sending Custom "Read Memory" block (Address: $028537, Count: $0F)
Sending Custom "Read Memory" block (Address: $028546, Count: $0F)
Sending Custom "Read Memory" block (Address: $028555, Count: $0F)
Sending Custom "Read Memory" block (Address: $028564, Count: $0F)
Sending Custom "Read Memory" block (Address: $028573, Count: $0F)
Sending Custom "Read Memory" block (Address: $028582, Count: $0F)
Sending Custom "Read Memory" block (Address: $028591, Count: $0F)
Sending Custom "Read Memory" block (Address: $0285A0, Count: $0F)
Sending Custom "Read Memory" block (Address: $0285AF, Count: $0F)
Sending Custom "Read Memory" block (Address: $0285BE, Count: $0F)
Sending Custom "Read Memory" block (Address: $0285CD, Count: $0F)
Sending Custom "Read Memory" block (Address: $0285DC, Count: $0F)
Sending Custom "Read Memory" block (Address: $0285EB, Count: $0F)
Sending Custom "Read Memory" block (Address: $0285FA, Count: $0F)
Sending Custom "Read Memory" block (Address: $028609, Count: $0F)
Sending Custom "Read Memory" block (Address: $028618, Count: $0F)
Sending Custom "Read Memory" block (Address: $028627, Count: $0F)
Sending Custom "Read Memory" block (Address: $028636, Count: $0F)
Sending Custom "Read Memory" block (Address: $028645, Count: $0F)
Sending Custom "Read Memory" block (Address: $028654, Count: $0F)
Sending Custom "Read Memory" block (Address: $028663, Count: $0F)
Sending Custom "Read Memory" block (Address: $028672, Count: $0F)
Sending Custom "Read Memory" block (Address: $028681, Count: $0F)
Sending Custom "Read Memory" block (Address: $028690, Count: $0F)
Sending Custom "Read Memory" block (Address: $02869F, Count: $0F)
Sending Custom "Read Memory" block (Address: $0286AE, Count: $0F)
Sending Custom "Read Memory" block (Address: $0286BD, Count: $0F)
Sending Custom "Read Memory" block (Address: $0286CC, Count: $0F)
Sending Custom "Read Memory" block (Address: $0286DB, Count: $0F)
Sending Custom "Read Memory" block (Address: $0286EA, Count: $0F)
Sending Custom "Read Memory" block (Address: $0286F9, Count: $0F)
Sending Custom "Read Memory" block (Address: $028708, Count: $0F)
Sending Custom "Read Memory" block (Address: $028717, Count: $0F)
Sending Custom "Read Memory" block (Address: $028726, Count: $0F)
Sending Custom "Read Memory" block (Address: $028735, Count: $0F)
Sending Custom "Read Memory" block (Address: $028744, Count: $0F)
Sending Custom "Read Memory" block (Address: $028753, Count: $0F)
Sending Custom "Read Memory" block (Address: $028762, Count: $0F)
Sending Custom "Read Memory" block (Address: $028771, Count: $0F)
Sending Custom "Read Memory" block (Address: $028780, Count: $0F)
Sending Custom "Read Memory" block (Address: $02878F, Count: $0F)
Sending Custom "Read Memory" block (Address: $02879E, Count: $0F)
Sending Custom "Read Memory" block (Address: $0287AD, Count: $0F)
Sending Custom "Read Memory" block (Address: $0287BC, Count: $0F)
Sending Custom "Read Memory" block (Address: $0287CB, Count: $0F)
Sending Custom "Read Memory" block (Address: $0287DA, Count: $0F)
Sending Custom "Read Memory" block (Address: $0287E9, Count: $0F)
Sending Custom "Read Memory" block (Address: $0287F8, Count: $0F)
Sending Custom "Read Memory" block (Address: $028807, Count: $0F)
Sending Custom "Read Memory" block (Address: $028816, Count: $0F)
Sending Custom "Read Memory" block (Address: $028825, Count: $0F)
Sending Custom "Read Memory" block (Address: $028834, Count: $0F)
Sending Custom "Read Memory" block (Address: $028843, Count: $0F)
Sending Custom "Read Memory" block (Address: $028852, Count: $0F)
Sending Custom "Read Memory" block (Address: $028861, Count: $0F)
Sending Custom "Read Memory" block (Address: $028870, Count: $0F)
Sending Custom "Read Memory" block (Address: $02887F, Count: $0F)
Sending Custom "Read Memory" block (Address: $02888E, Count: $0F)
Sending Custom "Read Memory" block (Address: $02889D, Count: $0F)
Sending Custom "Read Memory" block (Address: $0288AC, Count: $0F)
Sending Custom "Read Memory" block (Address: $0288BB, Count: $0F)
Error receiving block: Received block end $04 but expected $03. Block bytes: 03 67 09 04
Partial block: $03 $67 $09 $04
Error receiving blocks: Received block end $04 but expected $03. Block bytes: 03 67 09 04
Blocks received:
Block: $12 $65 $1B $8D $14 $0B $8D $2E $0B $AD $99 $02 $8D $15 $0B $8D $2F $0B $03
Caught: System.InvalidOperationException Received block end $04 but expected $03. Block bytes: 03 67 09 04
Unhandled exception: System.InvalidOperationException: Received block end $04 but expected $03. Block bytes: 03 67 09 04
at BitFab.KW1281Test.KW1281Dialog.ReceiveBlock() in /Users/gmenounos/src/kw1281test/KW1281Dialog.cs:line 411
at BitFab.KW1281Test.KW1281Dialog.ReceiveBlocks() in /Users/gmenounos/src/kw1281test/KW1281Dialog.cs:line 354
at BitFab.KW1281Test.Cluster.VdoCluster.CustomReadMemory(UInt32, Byte) in /Users/gmenounos/src/kw1281test/Cluster/VdoCluster.cs:line 94
at BitFab.KW1281Test.Cluster.VdoCluster.DumpMem(String, UInt32, UInt32) in /Users/gmenounos/src/kw1281test/Cluster/VdoCluster.cs:line 167
at BitFab.KW1281Test.Tester.DumpClusterMem(UInt32, UInt32, String) in /Users/gmenounos/src/kw1281test/Tester.cs:line 1082
at BitFab.KW1281Test.Tester.DumpMem(UInt32, UInt32, String) in /Users/gmenounos/src/kw1281test/Tester.cs:line 402
at BitFab.KW1281Test.Program.Run(String[]) in /Users/gmenounos/src/kw1281test/Program.cs:line 345
at BitFab.KW1281Test.Program.Main(String[]) in /Users/gmenounos/src/kw1281test/Program.cs:line 31
On the 4th attempt, the program ran until time out.
One detail: I managed to change the odometer with the ETSmart program calculator, directly on the encrypted file, without needing to decrypt it. Then, I wrote the EEPROM to the chip.
The only thing missing is changing the address 0x065 (SpeedSource) from $87 to $86 and 0x190 from 00 to $75, because the speedometer is not working and the fuel gauge is oscillating.
The requested dump is attached.
Also attached is the EEPROM currently written.
cluster_mem_$028000.bin (expected error)
cluster_mem_$028000.bin (time_out)
M93C86_CURRENT_KM_L7.bin
gmenounos
Watertown, MA, USA
Thanks! I'll work on changing those 2 bytes in the encrypted dump. While I do that, could you try dumping the ROM, starting from where it timed out?
kw1281test.exe COM3 10400 17 DumpMem 0x2CE39 0x4000
AndradeArt
Brazil
VW Polo 06/07
Thanks! Hopefully that part of the ROM will have the info I need. I've attached your encrypted EEPROM with the 2 patches applied. Let me know if it works.
It worked!!!!!
You are the best! I've been trying to get this cluster to work for almost 2 months.
Thank you very much!
Could you explain to me how you made this patch?
gmenounos
Watertown, MA, USA
It worked!!!!!
Glad to hear that it worked.
I was able to extract a secret key from the ROM dumps that you provided so I think you'll be able to read/write the EEPROM directly with kw1281test and not have to deal with the encryption anymore. Can you try this new release and see if that works?
https://github.com/gmenounos/kw1281test/releases/tag/v0.99-beta
Sure, I'll create a page on my cluster info site ( https://github.com/gmenounos/vwcluster ) that explains how the VDO 93C86 encryption works. At some point, when I have more time, I'll enhance the decryption web page to also allow editing and re-encryption.
In the meantime, could you please try to get me a couple more ROM dumps so I can learn more about your cluster?
kw1281test.exe COM3 10400 17 DumpMem 0x38000 0x4000
kw1281test.exe COM3 10400 17 DumpMem 0x3C000 0x4000
AndradeArt
Brazil
VW Polo 06/07
I tried GetSkc but it timed out :
Version 0.99.0-beta (https://github.com/gmenounos/kw1281test/releases)
Args: COM4 10400 17 GetSKC
.NET Version: 8.0.6
Culture: pt-BR
Opening serial port COM4
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Sending ReadIdent block
01: $90 $28
Unlock code for software version 'VQMJ09HH 05.10' is 37 42 47 43
Please report this to the program maintainer.
Access level is 7.
Saving EEPROM dump to 6QE920827C__KOMBIINSTRUMENT_VDO_V06_$0090_eeprom.bin
Sending ReadEeprom block (Address: $0090, Count: $10)
Caught: System.TimeoutException The operation has timed out.
Unhandled exception: System.TimeoutException: The operation has timed out.
at System.IO.Ports.SerialPort.ReadByte()
at BitFab.KW1281Test.KwpCommon.ReadComplement(Byte) in /Users/gmenounos/src/kw1281test/KwpCommon.cs:line 140
at BitFab.KW1281Test.KW1281Dialog.SendBlock(List`1) in /Users/gmenounos/src/kw1281test/KW1281Dialog.cs:line 345
at BitFab.KW1281Test.KW1281Dialog.ReadEeprom(UInt16, Byte) in /Users/gmenounos/src/kw1281test/KW1281Dialog.cs:line 143
at BitFab.KW1281Test.Cluster.VdoCluster.DumpEeprom(UInt16, UInt16, Byte, String) in /Users/gmenounos/src/kw1281test/Cluster/VdoCluster.cs:line 737
at BitFab.KW1281Test.Cluster.VdoCluster.DumpEeprom(Nullable`1, Nullable`1, String ) in /Users/gmenounos/src/kw1281test/Cluster/VdoCluster.cs:line 46
at BitFab.KW1281Test.Tester.DumpClusterEeprom(UInt16, UInt16, String ) in /Users/gmenounos/src/kw1281test/Tester.cs:line 903
at BitFab.KW1281Test.Tester.GetSkc() in /Users/gmenounos/src/kw1281test/Tester.cs:line 563
at BitFab.KW1281Test.Program.Run(String[]) in /Users/gmenounos/src/kw1281test/Program.cs:line 275
This command did not work in version 99, only in 98.
cluster_mem_$038000.bin
This other one didn't work in either of the 2 versions:
Args: COM2 10400 17 DumpMem 0x3C000 0x4000
.NET Version: 8.0.6
Culture: pt-BR
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Access level is 7.
Saving memory dump to cluster_mem_$03C000.bin
Sending Custom "Read Memory" block (Address: $03C000, Count: $0F)
at BitFab.KW1281Test.Interface.GenericInterface.ReadByte() in /Users/gmenounos/src/kw1281test/Interface/GenericInterface.cs:line 34
at BitFab.KW1281Test.KwpCommon.ReadComplement(Byte) in /Users/gmenounos/src/kw1281test/KwpCommon.cs:line 141
at BitFab.KW1281Test.Cluster.VdoCluster.SendCustom(List`1) in /Users/gmenounos/src/kw1281test/Cluster/VdoCluster.cs:line 199
at BitFab.KW1281Test.Cluster.VdoCluster.CustomReadMemory(UInt32, Byte) in /Users/gmenounos/src/kw1281test/Cluster/VdoCluster.cs:line 95
at BitFab.KW1281Test.Tester.DumpClusterMem(UInt32, UInt32, String) in /Users/gmenounos/src/kw1281test/Tester.cs:line 1108
gmenounos
Watertown, MA, USA
I made a typo in the previous release that's causing the "Unlock code for software version 'VQMJ09HH 05.10' is 37 42 47 43 Please report this to the program maintainer." message. Can you try this new release and see if the message goes away? https://github.com/gmenounos/kw1281test/releases/tag/v0.99.1-beta
I'm not sure what's causing the timeouts. Could you try the following command a few more times to verify that it always times out immediately?
Also maybe try the GetSKC a couple more times to verify that it always times out.
Thanks.
gmenounos
Watertown, MA, USA
can anyone help me retreive the cluster bin file using kw1281test?
clocks are bosch RB8.
If you want to dump the RB8 EEPROM, you would use the following command (replace "COM1" with the correct port that your cable is using):
kw1281test.exe COM1 10400 17 DumpRBxMem 66560 1024
If you just need the SKC, this is the easier way to get it:
kw1281test.exe COM1 10400 17 GetSKC
gmenounos
Watertown, MA, USA
cool Thats confirmed my skc but i still cant get my new clocks to adapt!!
Can you share some details of how you're trying to do the adaptation? Are you using kw1281test? VCDS?
What command are you using to try to do the adaptation?
gmenounos
Watertown, MA, USA
trying to use vcds to adapt.
full genuine cable(y)
Please post details about how you're trying to do the adaptation. What address are you connecting to? What login code are you using to login (old or new SKC)? What channel are you adapting? What value are you entering? What error message is being displayed that tells you that the adaptation isn't working?
You're not going to get much help if you just say "It won't adapt".
spoony
huddersfield uk
golf
read skc of old cluster and got skc 00751
connected new cluster and obtained skc 06326
then followed instructions from ross tech.
cluster, login, new cluster skc, adaption channel 50, enter old skc, test.
the four boxes at the top say, system, not ok, ?,?
save, close controller.
then turn ignition off for 1 minute.
When i turn on and check the vin and immo code havent changed!
hope this helps.
Amymore info needed please ask :)
gmenounos
Watertown, MA, USA
hope this helps.
Since you have VCDS, can you do an autoscan of all the modules in the car and post the results here?
spoony
huddersfield uk
golf
this before i did anything.........
Saturday,03,August,2024,17:42:06:28686
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WVWZZZ1JZ3W465667 License Plate:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ3W465667 Mileage: 269540km-167484miles
Address 01: Engine Labels: 06A-906-032-AJQ.clb
Part No: 06A 906 032 MJ
Component: 1.8L R4/5VT 0003
Coding: 11510
Shop #: WSC 00000
VCID: 72BED0103DB8217A597-5160
VINID: 9E69EAAAA05AA839C41851861C381F06E1
WVWZZZ1JZ3W465667 VWZ6Z0B0411629
No fault code found.
Readiness: 0010 1100
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 01271 785 00200
VCID: 34321608022C6F4A8BB-5184
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 01271
VCID: 211CEF5CA8DEEAE270D-51A8
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 0006
Coding: 12855
Shop #: WSC 01271
VCID: 221EE050ADD8F1FA697-5160
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 926 A
Component: KOMBI+WEGFAHRS. RB8 V28
Coding: 05414
Shop #: WSC 00000
VCID: 280AF278CBE41BAA373-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01271
VCID: 70BADA1833B4136AAF3-5160
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 1X Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 01271
VCID: 36362C0011507D5AB5F-4B3C
Subsystem 1 - Part No: 1C2959802A
Component: 1X Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C2959801A
Component: 1X Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 1X Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 1X Tõrsteuer.HR KLO 0009
End----(Elapsed Time: 04:51, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
and this after fitting new cluster and tried to adapt.....
Saturday,03,August,2024,20:04:48:28686
www.Ross-Tech.com
VIN: WVWZZZ1JZ3W304780 License Plate:
76
VIN: WVWZZZ1JZ3W304780 Mileage: 268700km-166962miles
Coding: 11510
Shop #: WSC 00000
VINID: 9E69EAAAA05AA839C30041C80060CEB0DE
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Coding: 0019970
Coding: 11000
Shop #: WSC 01271
1 Fault Found:
37-00 - Faulty
Coding: 12855
Shop #: WSC 01271
VCID: 221EE050ADD8F1FA697-513C
1 Fault Found:
Part No: 1J5 920 946 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 04412
Shop #: WSC 00000
VCID: 2F381964EE0A4C92F69-513C
WVWZZZ1JZ3W304780 VWZ7Z0B6042217
2 Faults Found:
01176 - Key
65-10 - Unauthorized - Intermittent
01177 - Engine Control Unit
Coding: 00006
Shop #: WSC 01266
VCID: 70BADA1833B4136AAF3-513C
Coding: 00258
Shop #: WSC 01271
VCID: 36362C0011507D5AB5F-4B1E
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
End----------(Elapsed Time: 04:59, VBatt start/end: 12.3V/12.3V)-----------
Hope this helps.
Regards
MIkey
gmenounos
Watertown, MA, USA
Try clearing the faults on the ECU and the cluster before doing the adaptation. Also check measuring blocks 022, 023 and 024 (especially 24):
If any of the lock times are not 0, you'll have to leave the key in the ignition and the cluster powered up until they get to 0.
Ashmeer
South Africa
1.8t
Hey Guys,
Hope everyone is well.
I've used the KW1281test, and managed to get my SKC after doing a dump of my Eeprom(had to ask for help with opening the file), I just wanted to find out if there are any sites/channels/links where i could learn more about dumping/flashing/opening these files. I'd like to learn more about software, tuning, coding etc.
Basically I'd like to learn a bit of everything if possible.
I do have some knowledge regarding PCs so it doesnt have to be very basic, I also have VCDS as well, kw1281test seems to be working just fine as well.
Any advice would be appreciated.
gmenounos
Watertown, MA, USA
Here are a couple of forums that specialize in that kind of thing:
Also there are some links at the very bottom of the following page in the "Credits" section: https://github.com/gmenounos/kw1281test
krook
Hungary
A4 B5 AWX, A4 B5 AFN
I've run into an issue trying to read the eeprom of my cluster just yesterday, this time I was using a ch340 blue cable. Here are the logs:
kw1281test did read, but the file is all 00s. in the end, I used vag k+can software to read the eeprom successfully, I'll attach it:
can you please take a look if my cluster number can be supported? I'm open to experiments
Blacktopsort
Venlo
Leon 1.9 tdi
Hi,
first of all thank you for an amazing job. Im fairly new to this coding stuff, I wanted to try to code my windows opening with my key fob, but I just cannot make it work. Does anyone here have a command line I can use to change it? I dont know to which value I have to change 04361, 04362 and 04363
