Hi All,
well done for job and support you are doing.
Does anyone succeed to sort this out"Caught: System.InvalidOperationException Controller did not wake up."
I tried with latest version with two different bands 10400 and 9600 but both with the same result
C:\Users\User\Desktop>kw1281test COM3 9600 17 GetSKC
KW1281Test: Yesterday's diagnostics...Today.
Version 0.82-beta (
https://github.com/gmenounos/kw1281test/releases)
Args: COM3 9600 17 GetSKC
OSVersion: Microsoft Windows NT 10.0.19045.0
.NET Version: 7.0.5
Culture: en-GB
Opening serial port COM3
Sending wakeup message
Wakeup duration: 2 seconds
Reading sync byte
Retrying wakeup message...
Reading sync byte
Reading sync byte
Unhandled exception: System.InvalidOperationException: Controller did not wake up.
at BitFab.KW1281Test.KwpCommon.WakeUp(Byte, Boolean) in C:\Users\gmeno\src\kw1281test\KwpCommon.cs:line 63
at BitFab.KW1281Test.Tester.Kwp1281Wakeup(Boolean ) in C:\Users\gmeno\src\kw1281test\Tester.cs:line 32
at BitFab.KW1281Test.Tester.GetSkc() in C:\Users\gmeno\src\kw1281test\Tester.cs:line 484
at BitFab.KW1281Test.Program.Run(String[]) in C:\Users\gmeno\src\kw1281test\Program.cs:line 249
at BitFab.KW1281Test.Program.Main(String[]) in C:\Users\gmeno\src\kw1281test\Program.cs:line 26
C:\Users\User\Desktop>kw1281test COM3 10400 17 GetSKC
Version 0.74-beta (
Args: COM3 10400 17 GetSKC
.NET Version: 6.0.2
Culture: en-GB
Reading sync byte
Reading sync byte
Reading sync byte
at BitFab.KW1281Test.KwpCommon.WakeUp(Byte controllerAddress, Boolean evenParity) in C:\Users\gmeno\src\kw1281test\KwpCommon.cs:line 63
at BitFab.KW1281Test.Tester.Kwp1281Wakeup(Boolean evenParityWakeup) in C:\Users\gmeno\src\kw1281test\Tester.cs:line 31
at BitFab.KW1281Test.Tester.GetSkc() in C:\Users\gmeno\src\kw1281test\Tester.cs:line 427
at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 241
at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 26
and also tried kw1281test COM3 10400 17 DumpRBxMemOdd 66560 1024
but again Controller did not wake up.
what I am doing so wrong? Dongle is vag kkl 409.1 with WIN10, drivers installed correctly. Tying to get SKC from VW Tauran 1.9TDi Instrument cluster is VDD.
thank you for your help
