kw1281test: A Free VDS-Pro / VagTacho Alternative
AJ_27
NWT, Canada
Golf City 2007
Code:
C:\Users\alexj>DESKTOP.\kw1281test.exe COM5 10400 17 GetSKC
KW1281Test: Yesterday's diagnostics...Today.
Version 0.80-beta (https://github.com/gmenounos/kw1281test/releases)
Args: COM5 10400 17 GetSKC
OSVersion: Microsoft Windows NT 10.0.22000.0
.NET Version: 7.0.0
Culture: en-CA
Opening serial port COM5
Sending wakeup message
Wakeup duration: 2 seconds
Reading sync byte
Caught: System.IO.IOException This operation returned because the timeout period expired. : 'COM5'
Unhandled exception: System.IO.IOException: This operation returned because the timeout period expired. : 'COM5'
   at System.IO.Ports.SerialStream.EndRead(IAsyncResult)
   at System.IO.Ports.SerialStream.ReadByte(Int32)
   at System.IO.Ports.SerialStream.ReadByte()
   at System.IO.Ports.SerialPort.ReadByte()
   at BitFab.KW1281Test.Interface.GenericInterface.ReadByte() in C:\Users\gmeno\src\kw1281test\Interface\GenericInterface.cs:line 34
   at BitFab.KW1281Test.KwpCommon.WakeUp(Byte, Boolean) in C:\Users\gmeno\src\kw1281test\KwpCommon.cs:line 52
   at BitFab.KW1281Test.Tester.Kwp1281Wakeup(Boolean ) in C:\Users\gmeno\src\kw1281test\Tester.cs:line 32
   at BitFab.KW1281Test.Tester.GetSkc() in C:\Users\gmeno\src\kw1281test\Tester.cs:line 482
   at BitFab.KW1281Test.Program.Run(String[]) in C:\Users\gmeno\src\kw1281test\Program.cs:line 243
   at BitFab.KW1281Test.Program.Main(String[]) in C:\Users\gmeno\src\kw1281test\Program.cs:line 26
Hey Guys, I'm trying to retrieve my SKC code for my Golf City 2007 (Canada) in order to do a key adaptation. I've tried a couple times but I get a timeout period expired error.
Kalmurn
Vancouver Island, Canada
2004 Jetta Wagon TDI
Well Im happy to report that I was able to get it to work successfully with a friends cheap obd2-USB cable functioning as a COM port. I was able to get my SKC code and using that SKC code i was able to program another key using VCDS.
I already have the "windows roll up and down function with the key fob buttons enabled using Motordiag Komfort Manager Lite 1.20 (Details here for how to do this) so now I need to figure out what else i want to do with kw1281test! Many thanks to all of your work on this project!
Some additional info for anyone attempting to use the SKC code to program a new key.
I was initially trying some other ways of potentially disabling the immobilizer as well as programing the key but nothing was working. I was getting the word "FAIL" where the trip meter was in the bottom right corner. I also got this when I was attempting to login in for adaptation with VCDS and also when attempting to use the adaptation function of kw1281test which would cause it to error out with a timeout. This was because the immobilizer had been triggered and there was a countdown timer in the cluster preventing login. If you go to the instuments section of VCDS and view measuring block 24. If the first field is greater than 0 you will not be able to log in with VCDS and im assuming this was also preventing the use of kw1281test from logging in for adaptation settings. Some more detail here
AJ_27
NWT, Canada
Golf City 2007
Success, I was able to retrieve my SKC code for my City Golf 2007 and adapt my new key using VCDS (Hex+Can cord). I was getting a timeout period expired problem. I was playing around in the options and I unchecked the "Boot in intelligent mode" and I believe I checked the " Bypass Can Init" box and it worked.
Thanks to gmenounos your program and this awesome forum saved my car. Some kids broke into my apartment on boxing day and stole all my car keys amongst other things. Living in the Canadian Sub-artic made this situation particularly ****ty with no Volks dealership or capable locksmith where I live ( Yellowknife ). I was looking at a 2000$+ tow to closest dealership (Edmonton).
Code:
.NET Version: 7.0.0
Culture: en-CA
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
Caught: System.InvalidOperationException Received block end $20 but expected $03
Unhandled exception: System.InvalidOperationException: Received block end $20 but expected $03
   at BitFab.KW1281Test.KW1281Dialog.ReceiveBlock() in C:\Users\gmeno\src\kw1281test\KW1281Dialog.cs:line 392
   at BitFab.KW1281Test.KW1281Dialog.ReceiveBlocks() in C:\Users\gmeno\src\kw1281test\KW1281Dialog.cs:line 351
   at BitFab.KW1281Test.KW1281Dialog.Connect() in C:\Users\gmeno\src\kw1281test\KW1281Dialog.cs:line 91
   at BitFab.KW1281Test.Tester.Kwp1281Wakeup(Boolean ) in C:\Users\gmeno\src\kw1281test\Tester.cs:line 39
.NET Version: 7.0.0
Culture: en-CA
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 1J0920807A  KOMBI+WEGFAHRSP VDO V03
Software Coding 11332, Workshop Code: 00000
Sending ReadIdent block
Sending Custom "Read Software Version" blocks
Sending Custom "Unlock Additional Commands" block
00: VWK503LL $00 $09
01: $58 $20
02: $13 $0B $02 $0D $35 $04
03: VW/Sk LL ROM-Maske
Sending Custom "Unlock partial EEPROM read" block
Unlock code for software version 'VWK503LL 09.00' is 3E 35 3D 3A
Sending Custom "Need Seed/Key?" block
Sending Custom "Seed request" block
Block:  F4 AA DD A1 37 53 8C 7B 01 00
Sending Custom "Key response" block
Cluster is unlocked for ROM/EEPROM access.
Saving EEPROM dump to 9BWEL41J374000448_____VWZ7Z0F4023816_$0090_eeprom.bin
Sending ReadEeprom block (Address: $0090, Count: $10)
Received "Read EEPROM Response" block: 7B B1 6D 27 7B B1 13 4A FF FF FF FF FF FF FF FF
Sending ReadEeprom block (Address: $00A0, Count: $10)
Received "Read EEPROM Response" block: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Sending ReadEeprom block (Address: $00B0, Count: $10)
Received "Read EEPROM Response" block: C8 0B 6D 49 26 8B A7 FF C8 0B 6D 49 26 8B A7 FF
Sending ReadEeprom block (Address: $00C0, Count: $10)
Received "Read EEPROM Response" block: C8 0B 6D 49 26 8B A7 FF 22 22 22 06 06 06 00 0C
Sending ReadEeprom block (Address: $00D0, Count: $10)
Received "Read EEPROM Response" block: 40 00 02 00 10 10 10 01 14 FF FF 30 FF FF FF FF
Sending ReadEeprom block (Address: $00E0, Count: $10)
Received "Read EEPROM Response" block: 56 57 5A 37 5A 30 46 34 30 32 33 38 31 36 56 57
Sending ReadEeprom block (Address: $00F0, Count: $10)
Received "Read EEPROM Response" block: 5A 37 5A 30 46 34 30 32 33 38 31 36 56 57 5A 37
Sending ReadEeprom block (Address: $0100, Count: $0C)
Received "Read EEPROM Response" block: 5A 30 46 34 30 32 33 38 31 36 F1 10
Saved EEPROM dump to 9BWEL41J374000448_____VWZ7Z0F4023816_$0090_eeprom.bin
SKC: 04337
Sending EndCommunication block
Cheers.
caffeine
B.C., Canada
2010 A6 Avant with BHW/6HP-19A conversion
I hope you deactivated the stolen key in Vagcom.
Great to hear this works on Mk5's too.
Programming new keys automatically erases any previously programmed keys. Also, City Golfs and City Jettas are not Mk5s, they're more like a facelifted Mk4 sold in Canada, Mexico, and some other markets. They're basically identical to the last Mk4s but with different bumpers, fenders, headlights, taillights, and in the case of the City Jetta, trunks.
T.Hollister
Texas
2002 Beetle GLS ALH, 2003 Jetta GLS ALH
Trying to get the skc code on a 2003 jetta tdi, getting a controller dont wake up error?
C:\Users\black>C:\Users\black\Desktop\kw1281test.exe com3 10400 17 GetSKC
Version 0.71-beta (https://github.com/gmenounos/kw1281test/releases)
Args: com3 10400 17 GetSKC
OSVersion: Microsoft Windows NT 10.0.25267.0
.NET Version: 6.0.0
Culture: en-US
Opening serial port com3
Reading sync byte
Retrying wakeup message...
Reading sync byte
Reading sync byte
Caught: System.InvalidOperationException Controller did not wake up.
Unhandled exception: System.InvalidOperationException: Controller did not wake up.
at BitFab.KW1281Test.KwpCommon.WakeUp(Byte controllerAddress, Boolean evenParity) in C:\Users\gmeno\src\kw1281test\KwpCommon.cs:line 59
at BitFab.KW1281Test.Program.Kwp1281Wakeup(Boolean evenParityWakeup) in C:\Users\gmeno\src\kw1281test\Program.cs:line 364
at BitFab.KW1281Test.Program.GetSkc() in C:\Users\gmeno\src\kw1281test\Program.cs:line 749
at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 296
at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 30
got this working now, replaced the cable and was good to go
gmenounos
Watertown, MA, USA
'99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion), Non-TDI: '23 Tesla Model 3 AWD
To anyone reporting "Controller did not wake up." errors, please include info about what kind of cable you're using. kw1281test reports some info about your setup in its log, but it doesn't know anything about your particular cable other than what COM port it's configured as. I'll add some more troubleshooting info to the error message and write up some documentation when I get time.
Joe De Guy
So Calif
2004 Jetta Wagon
Hi, new to the forum. Have the cable, ran the script and i was able to pull my SKC digits. But when I go to login with my VCDS it doesn't recognize the SKC. Am I missing a step somewhere?
gmenounos
Watertown, MA, USA
Joe De Guy
So Calif
2004 Jetta Wagon
Thanks, figured it out. I was logging into Immobilizer rather than instrument 17. When I logged in there everything else flowed, Thanks for the quick help, much appreciated.
Joe
T.Hollister
Texas
Wanting to do some cluster mods on a 2003 Jetta. Was thinking of adding fis. I would love a color one but they seem to be difficult to get. Is there any vehicles they can be salvaged from or clusters that can be used? I have a half display Passat cluster I can modify if I can’t do the color. I am on the lookout for the full size display.
caffeine
B.C., Canada
Color LCDs never came factory in a Mk4-compatible cluster. Full size mostly only sold in Europe. I think the only exception in North America was the W8 Passat.
Mozambiquer
Versailles Missouri
I've got a w8 cluster if you want one of them. The color mfa didn't come on any of the USA vehicles stock that I know of. Clustersbylitke does the conversions for those, but its not cheap.
I also have sport tdi faces to do the w8 conversion.
T.Hollister
Texas
What are you asking for the lot? What all would I need to do the conversion. Mine is a tdi too
gmenounos
Watertown, MA, USA
T.Hollister
Texas
Very good write up, sorry i didn't spot it sooner. I did a quick check for then bin file using the search info but didnt find any copies. anyplace you recommend to get it?
himtan
Greece
Polo mk4
Hello, i tried to retrieve my code but it didn't work (VW POLO 9N 2004). Can anyone help me ? I attached a photo of the results and the bin file.
Thanks in advance.
Code:
Bin file extracted by the program : https://www.file.io/txwu/download/bPgSkRqgbtRz
Code:
Args: com5 10400 17 GetSKC
OSVersion: Microsoft Windows NT 10.0.18363.0
.NET Version: 7.0.0
Culture: el-GR
Opening serial port com5
Wakeup duration: 2,0000001 seconds
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 6Q0920820  KOMBI+WEGFAHRSP VDO V18
Software Coding 01141, Workshop Code: 00000
00: VSQX01LM $10 $01
01: $69 $19
02: $07 $0B $01 $0B $1B $15
03: PQ24_2 LM KW18/02
Unlock code for software version 'VSQX01LM 01.10' is 43 43 3D 37
Please report this to the program maintainer.
Block:  AD F9 96 FB F2 CC 27 FF 03 00
Unexpected seed suffix: $03 $00, (Expected $01 $00)
Failed to unlock cluster.
Saving EEPROM dump to WVWZZZ9NZ4Y196884_____VWZ7Z0D9050062_$0090_eeprom.bin
*** Warning: Some bytes could not be read and were replaced with 0 ***
Saved EEPROM dump to WVWZZZ9NZ4Y196884_____VWZ7Z0D9050062_$0090_eeprom.bin
GetSkc: Unable to find Immobilizer ID in cluster dump.
Unable to determine SKC.
gmenounos
Watertown, MA, USA
Thanks in advance.
I think you're the 3rd person to ask for help with this kind of cluster. I have one now, but I need wiring information before I can even attempt to add support. Does anyone know which wires on the back of this cluster are power, ground and K-Line?
himtan
Greece
Polo mk4
From ELSA program i have found the following :
Code:
32-pin connector, green
1 -     Reading coil for immobilizer 1
2 -     Main beam warning lamp, terminal 56a
3 -     Not assigned
4 -     Oil temperature and level signal
5 -     Electronic speedometer output signal
6 -     Input signal to electronic speedometer
7 -     Drivetrain CAN, low
8 -     Drivetrain CAN, high
9 -     Convenience CAN, low
10 -     Convenience CAN, high
11 -     MFI call-up button - top (display switches down)
12 -     MFI call-up button - bottom (display switches up)
13 -     Not assigned
14 -     Not assigned
15 -     Fuel gauge
16 -     Coolant low indicator
17 -     Reading coil for immobilizer 2
18 -     Rear fog light warning lamp
19 -     Fog light warning lamp
20 -     Seat belt warning system
21 -     Handbrake warning lamp
22 -     Brake system warning lamp
23 -     Pressure switch
24 -     CAN wake-up
25 -     Drivetrain CAN, screen
26 -     Convenience CAN, screen
27 -     MFI save switch - reset
28 -     Not assigned
29 -     Not assigned
30 -     Washer fluid low
31 -     Ambient temperature sensor input signal
32 -     Terminal 31 sensor earth
8-pin connector, black
1 -     Brake pad wear
2 -     Not assigned
3 -     Not assigned
4 -     Right parking light
5 -     Terminal 15, positive
6 -     Left parking light
7 -     Terminal 30, positive
8 -     Terminal 31, earth
Thanks in advance
gmenounos
Watertown, MA, USA
I don't see the K-Line listed. If you look in ELSA, does the OBD-II diagnostic connector have a K-Line? If so, where does it go? Is there some external CAN-gateway that converts the K-Line signal to the CAN bus and routes it to the cluster?
kw1281test only works if the car supports K-line-based diagnostics.
himtan
Greece
Polo mk4
Sorry i don't know :confused:
imaginifer
Czech Republic
Škoda Fabia I 1.4 TDI
Hello again and sorry for the delay. Here is the wiring from the Czech service manual of Škoda Fabia, description is much the same as himtan posted. Unfortunately there is absolutely nothing about "K-Line" in the manual.
Nawalski
Sydney Australia
2008 Jetta
Hi sorry but I'm new here to TDI and to the whole forum thing, possibly my age. I have read through the 40 pages and am trying to retrieve my SKC for a 2008 Jetta in AUS. I have followed all advice and seem to be getting a timed out error. I am using a VCDS HEX+CAN dongle bought from Ross Tech Vag18.9. VCP drivers are setup correctly. I have run the script and get the following and appologise as I didn't know another way of pasting it in "age showing again"
C:\Users\Home\Desktop>kw1281test COM2 10400 17 GetSKC
Args: COM2 10400 17 GetSKC
OSVersion: Microsoft Windows NT 6.1.7601 Service Pack 1
.NET Version: 7.0.0
Culture: en-AU
Opening serial port COM2
Wakeup duration: 1.9999968421247922 seconds
Reading sync byte
expired. : 'COM2'
timeout period expired. : 'COM2'
cs:line 482
rogram.cs:line 243
Program.cs:line 26
gmenounos
Watertown, MA, USA
A 2008 Jetta uses CAN bus for diagnostics, not K-Line (source: https://www.ross-tech.com/vcds/canbus.php) so kw1281test isn't going to work for you. Sorry.
krstecd
Macedonia
Golf 5 1.9TDI Goal 2006
Q: What is kw1281test?
A: It's a program I wrote in 2020 to help TDI VW VAG owners retrieve their vehicle's SKC and program their CCMs using a generic KKL cable that you can probably pick up for $20 or so. It runs on Windows 10/11, macOS and Linux. It's open source so you can copy it, modify it or just read through the source code to understand how it works. But it's a command line program and only works with cars that support diagnostics via the K-Line. For VWs, this means only MKIV cars are supported.
Can i somehow get my SKC code on my Golf 5 1.9TDI Goal 2006? Is this gonna work?
I tried to run vag can commander on my HEX USB cable with tmega162 IC that i bought from aliexpress but i cant get it to work.
gmenounos
Watertown, MA, USA
Sorry, it won't work with the Golf 5 or any other car that uses the CAN bus for diagnostics: https://www.ross-tech.com/vcds/canbus.php
gmenounos
Watertown, MA, USA
Any other solution to retrieve my SKC code without buying other cables?
Not that I know of. I only have MK4 cars so I don't know how to add support for anything newer (which would also require a different cable).
