kw1281test: A Free VDS-Pro / VagTacho Alternative
ekincaid
North Carolina
03 Golf TDI
Maybe try 4800 then.
I probably won't have time to try the different baud rate for a few days. I do have a question though... Where are these error codes being stored?
If I understand correctly when I use the command
kw1281test.exe COM1 9600 15 ReadFaultCodes
I am requesting from controller address 15. The help doesn't mention this location
ADDRESS = The controller address, e.g. 1 (ECU), 17 (cluster), 46 (CCM), 56 (radio)
I don't mean to be a pain. Just trying to understand as best I can
Troyboy163
usa
alh
thank you gmenounos! I got my new key working using kw1281test to retrieve the SKC. That was very easy to use. I'm not used to github things being straight forward :)
I used this cable with drivers found on the internet and windows 11
semi off topic but if the SKC does not work in VCDS, its not the wrong code. You have to clear the fault codes in the cluster with VCDS prior to inputting the SKC and it will work fine. My case it was a aftermarket head unit. The cluster throws a code because its not communicating with the stock radio.
gmenounos
Watertown, MA, USA
New version: https://github.com/gmenounos/kw1281test/releases/tag/v0.79-beta
  • Added GetClusterId command to get the cluster Id (used by the radio to determine if it's been installed in a new vehicle).
  • Some 1J0919 clusters have an SKC so added code to work with them.
GetClusterId, which doesn't appear in the official list of commands and doesn't have much use unless you're a VW radio :), is used to retrieve the 16-bit cluster Id. Usage (note "3F" address instead of "17") :
.\kw1281test.exe COM1 10400 3F GetClusterId
More info here: https://github.com/mnaberez/vwradio/blob/main/reverse_engineering/delco/vw_premium_5/kwp1281_0x3f.md
touaregv10tdi
Fort Lauderdale - Florida
2013 Beetle TDi,2001 Beetle TDi,2015 Passat TDi, 2016 BMW X5 Diesel
I did everything I could using vag commander I cant retrieve my SKC key. When I connect to the car , select engine then read EEPROM
I get response saying cannot connect to device.
gmenounos
Watertown, MA, USA
Ah, which car in your fleet are you talking about? Also, this thread is mostly about kw1281test, not VAG Commander, so it might be worth creating a new thread for the issue you're having.
silverfox64
México
Clasico
Hello cordial greeting, I wish, first thank for this great program, and second please if you could put support for Immobox, 377 953 257 A, with memory 93c56, VW Pointer, (in Mexico) in Brazil, Parathi, and Valeo Immobox, (Vag PN: 6x0953257) With Memory 24C04, Derby, for thanksgiving, a hug from Mexico.:love::eek: And it worked very well in a Clasico 2013 VDO V75, to retrive Pin code (Mexico).
gmenounos
Watertown, MA, USA
As far as I know, there isn't a known way to retrieve the SKC from dedicated immobilizer boxes via a KKL cable. You have to open the box and read the EEPROM with a hardware device. If someone knows differently, let me know.
silverfox64
México
Clasico
Hello cordial greeting, precisely with the vagtacho, you can extract the pin code, attached a PDF, Vagtacho pin code Pointer, from how to extract it with the vagtacho, for the attention thank you.
silverfox64
México
Clasico
That's good to know, but it's for a Kostal immo box, which I don't have and can't even find here in the US.
Thank you very much for answering, but it is also for immobox "Megamos", transponder (ID48), but if you can't, i appreciate the attention anyway, a hug from Mexico. :unsure::cry:o_O
ekincaid
North Carolina
03 Golf TDI
I think so. The following command will read the airbag fault codes (Replace "COM1" with your actual COM port):
.\kw1281test.exe COM1 9600 15 ReadFaultCodes
The following command should clear the airbag fault codes:
.\kw1281test.exe COM1 9600 15 ClearFaultCodes
The current version (0.76-beta) of kw1281test has a bug so it'll give you this error:
Code:
Sending ClearFaultCodes block
Caught: System.InvalidOperationException ClearFaultCodes returned 2 blocks instead of 1
But it should still clear the fault codes and hopefully reset your airbag light.
@gmenounos It took me a lot longer to get back to this than I hoped. Everything worked great. Had to use a baud rate of 10400. Thanks.
locarno
Poland
1.6 16V
It is possible to read and write MagnetiMarelli IAW4 ECU with this tool? Part number 036906034bb
gmenounos
Watertown, MA, USA
You should be able to connect, read the identification info and read/clear DTCs, but that's about it. kw1281test only supports reading the EEPROM and getting the SKC from EDC15 ECUs. It doesn't currently support writing to any ECUs other than clearing DTCs and changing adaptation/coding.
scooter133uk
UK
Beetle 1.8T
Reading lots and trying lots but getting these errors, any ideas?
Version 0.79-beta (https://github.com/gmenounos/kw1281test/releases)
Args: COM2 9600 17 DumpBeetleMem 14336 2048
OSVersion: Microsoft Windows NT 10.0.19044.0
.NET Version: 6.0.9
Culture: en-GB
Opening serial port COM2
Sending wakeup message
Wakeup duration: 2 seconds
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
ECU: 1C0920905F KOMBI+WEGFAHRS. M73 V03
Software Coding 05412, Workshop Code: 00000
Usage: KW1281Test PORT BAUD ADDRESS COMMAND [args]
PORT = COM1|COM2|etc.
BAUD = 10400|9600|etc.
COMMAND =
ActuatorTest
AdaptationRead CHANNEL [LOGIN]
CHANNEL = Channel number (0-99)
LOGIN = Optional login (0-65535)
AdaptationSave CHANNEL VALUE [LOGIN]
VALUE = Channel value (0-65535)
AdaptationTest CHANNEL VALUE [LOGIN]
BasicSetting GROUP
GROUP = Group number (0-255)
(Group 0: Raw controller data)
ClarionVWPremium4SafeCode
ClearFaultCodes
DelcoVWPremium5SafeCode
DumpEdc15Eeprom [FILENAME]
FILENAME = Optional filename
DumpEeprom START LENGTH [FILENAME]
START = Start address in decimal (e.g. 0) or hex (e.g. $0)
LENGTH = Number of bytes in decimal (e.g. 2048) or hex (e.g. $800)
DumpMarelliMem START LENGTH [FILENAME]
START = Start address in decimal (e.g. 3072) or hex (e.g. $C00)
LENGTH = Number of bytes in decimal (e.g. 1024) or hex (e.g. $400)
DumpMem START LENGTH [FILENAME]
START = Start address in decimal (e.g. 8192) or hex (e.g. $2000)
LENGTH = Number of bytes in decimal (e.g. 65536) or hex (e.g. $10000)
DumpRBxMem START LENGTH [FILENAME]
START = Start address in decimal (e.g. 66560) or hex (e.g. $10400)
FindLogins LOGIN
LOGIN = Known good login (0-65535)
GetSKC
GroupRead GROUP
LoadEeprom START FILENAME
FILENAME = Name of file containing binary data to load into EEPROM
MapEeprom
ReadFaultCodes
ReadIdent
ReadEeprom ADDRESS
ADDRESS = Address in decimal (e.g. 4361) or hex (e.g. $1109)
ReadRAM ADDRESS
ReadROM ADDRESS
ReadSoftwareVersion
Reset
SetSoftwareCoding CODING WORKSHOP
CODING = Software coding in decimal (e.g. 4361) or hex (e.g. $1109)
WORKSHOP = Workshop code in decimal (e.g. 4361) or hex (e.g. $1109)
ToogleRB4Mode
WriteEeprom ADDRESS VALUE
VALUE = Value in decimal (e.g. 138) or hex (e.g. $8A)
Sending EndCommunication block
.NET Version: 6.0.9
Culture: en-GB
Caught: System.UnauthorizedAccessException Access to the path 'COM2' is denied.
Unhandled exception: System.UnauthorizedAccessException: Access to the path 'COM2' is denied.
at System.IO.Ports.SerialStream..ctor(String , Int32 , Parity , Int32 , StopBits , Int32 , Int32 , Handshake , Boolean , Boolean , Boolean , Byte )
at System.IO.Ports.SerialPort.Open()
at BitFab.KW1281Test.Interface.GenericInterface..ctor(String portName, Int32 baudRate) in C:\Users\gmeno\src\kw1281test\Interface\GenericInterface.cs:line 23
at BitFab.KW1281Test.Program.OpenPort(String portName, Int32 baudRate) in C:\Users\gmeno\src\kw1281test\Program.cs:line 399
at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 232
at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 26
.NET Version: 6.0.9
Culture: en-GB
.NET Version: 6.0.9
Culture: en-GB
.NET Version: 6.0.9
Culture: en-GB
.NET Version: 6.0.9
Culture: en-GB
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
COMMAND =
ActuatorTest
BasicSetting GROUP
ClearFaultCodes
FindLogins LOGIN
GetSKC
GroupRead GROUP
MapEeprom
ReadFaultCodes
ReadIdent
ReadEeprom ADDRESS
ReadRAM ADDRESS
ReadROM ADDRESS
ReadSoftwareVersion
Reset
ToogleRB4Mode
gmenounos
Watertown, MA, USA
.NET Version: 6.0.9
Culture: en-GB
There is no DumpBeetleMem command. Well there used to be, but it's now named DumpMarelliMem because there are other cars such as Audi TT that use the same command. So you should try:
.\kw1281test.exe COM2 9600 17 DumpMarelliMem 3072 1024
.\kw1281test.exe COM2 9600 17 DumpMarelliMem 14336 2048
and see if either of those commands work. Please report back if either one does.
Not sure what's causing the "System.UnauthorizedAccessException Access to the path 'COM2' is denied." error. Any chance you had the 2 programs trying to access COM2 at the same time? Or maybe ran kw1281test when the cable wasn't plugged in?
scooter133uk
UK
Beetle 1.8T
Cheers for fast reply. I got a bin file, how do I get the SKC now pls? I have loaded it into Hxd but not sure where I'm looking now.
bin file
V03905F ÿ ÿÿÿÿÿÿ04 ÿÿ*H Bx{ÿÿÿÿÿÿÿÿÿÿÿ - % %ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿhÿÿÿÿÿÿÿÿÿÿÿÿ‡ÿÿÿ2 Bÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ¼ ÿÿ ³ÿ
8\yžÙ)YxšÁÞ 5Dÿÿÿÿÿÿ «5Îi0ÜÓ‡LG ¾ ¾ ¾ÿÿÿÿÿÿ 55ÿÿ ´~#¸(Š–¼ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿ10//231102110.-/-00,.,,+1ÿÿÿ#ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ* $"9$ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿh †+X þ°
ò A – ï0ÿyþÔþ§ÿïÿÿÿÿOÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿèÿÿÿÿÿÿÿÿ ƒ¥ƒ«ìƒ²Ðƒ¹´ƒÀ˜ƒÇ|ƒÎ`ƒÕDƒÜ(ƒãƒéðƒðÔƒ÷¸ƒþœ„€„d„H„,„!„'ô„.Ø„5¼„< „C„„Jh„QL„X0„_„eø„lÜ„sÀ„z¤„ˆ„ˆl„P„–4ƒ—@ƒž$÷|Z÷÷|T÷|M/÷|FK÷|?g÷|8ƒ÷|1Ÿ÷|*»÷|#×÷|ó÷|÷|+÷|G÷|c÷{ú÷{ó›÷{ì·÷{åÓ÷{Þï÷{Ø÷{Ñ'÷{ÊC÷{Ã_÷{¼{÷{µ—÷{®³÷{§Ï÷{ ë÷{š÷{“#÷{Œ?÷{…[÷{~w÷{w“÷{p¯÷{iË÷|h¿÷|aÛÿ]ÿÿÿX¬§S¹ ÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿZ3262386ÿÿÿÿÿÿ1#A`v”¶KÕ]KŒìeK޲ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ1#A`v”¶KÕ]KŒìeK޲ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ1#A`v”¶KÕ]KŒìeK޲ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
gmenounos
Watertown, MA, USA
bin file
Can you upload the .bin file as an attachment? (use the "Attach files" button)
krook
Hungary
A4 B5 AWX, A4 B5 AFN
Hey! I have a new-to-me Audi A4 that has a rather rare 920 white background cluster. As far as I know, it's a VDO make. My problem is that it does not light up when I twist the ignition, only when I turn the lights on. I know this can be fixed by AudiDashEdit, but I can't seem to read (let alone write) the EEPROM of the cluster. I tried VAG Eeprom programmer 1.19 and kw1281test 0.79 but none of those can seem to read the cluster. Can you help me? I tried 8400, 9600 speeds as well, but they crashed even earlier. The only way I got a response was by using 10400. I also tried DumpMarelliMem, but that doesn't work either.
Args: COM2 10400 17 ReadEeprom 0
OSVersion: Microsoft Windows NT 10.0.22000.0
.NET Version: 6.0.9
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 8D0920932C B5-KOMBIINSTR. VDO D12
Software Coding 00140, Workshop Code: 50311
Sending Custom "Read Software Version" blocks
Sending Custom "Unlock Additional Commands" block
Cluster did not return software version.
Unknown cluster software version. EEPROM access will likely fail.
Sending Custom "Need Seed/Key?" block
Sending Custom "Seed request" block
Failed to unlock cluster.
Sending ReadEeprom block (Address: $0000, Count: $01)
EEPROM read failed
Thanks in advance!
gmenounos
Watertown, MA, USA
.NET Version: 6.0.9
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
EEPROM read failed
Thanks in advance!
DumpMarelliMem won't work because your cluster is made by VDO: "ECU: 8D0920932C B5-KOMBIINSTR. VDO D12"
It's not likely that I can add support for that cluster because it seems different than any of the other ones that kw1281test supports. Maybe if someone sends me one, I could do it...
Your best bet might be to get an EEPROM programmer, take apart the cluster and physically read/write the EEPROM as described here: https://www.drive2.com/l/527235342923726903/
