kw1281test: A Free VDS-Pro / VagTacho Alternative
mur3633
Podgorica, Montenegro
Mk4 PD TDI
Thank you for this bro!🍺 Remote windows activated with brand new Acer Win10 laptop, VAG Commander 1.4 Chinese cable and 1J0 CCM in Mk4 Golf MY2001
gmenounos
Watertown, MA, USA
'99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion), Non-TDI: '23 Tesla Model 3 AWD
Awesome. You're the first person I've heard successfully using it. Glad it worked for you!
Nuje
Island near Vancouver
For a 2002 cluster, you want to do something like (assuming your port is COM4):
kw1281test.exe COM4 10400 17 DumpEeprom 204 6
You should get 3 identical pairs of values back. Here's a sample:
Received "Read EEPROM Response" block: 07 0B 07 0B 07 0B
Multiply the second number by 256 and add the first number, keeping in mind that 0A = 10, 0B = 11, 0C = 12, 0D = 13, 0E = 14, 0F = 15. So for the example here, (11 x 256) + 7 = 2823 so SKC = 02823
Would the process be any different on a 2003 cluster? Specifically, a Bosch RB8 (not the VDO that I'm used to dealing with)?>
gmenounos
Watertown, MA, USA
It's highly unlikely that my program will even work with a Bosch RB8. The commands it uses to unlock the cluster for reading/writing the EEPROM probably only work on VDO clusters. And even if they worked, the EEPROM is much smaller and the SKC is almost certainly in a different location.
KrashDH
Washington
2002 Golf
hey @Nuje , I was able to set up my COM port, but when I go into VCDS to test COM2 it says it's not available...Do I need to keep the USB port active in VCDS? Or should I be linked to COM2 if I did it correct?
KrashDH
Washington
2002 Golf
So it shows my cable under COM2, but VCDS doesn't recognize that COM (which I think is ok, it still recognizes the USB interface).
So for my Powershell code, I would run it like this, correct?
kw1281test.exe COM2 10400 17 DumpEeprom 204 6
What are these numbers referring to "10400", "17" and "204 6"?
My CCOM2 setting has a b/s rate of 9600....do I need to use that instead of the 10400? Where are the other 2 cluster of numbers gotten from?
gmenounos
Watertown, MA, USA
10400 is the baud rate (basically the speed that it talks to the control module). It doesn't matter what speed your COM2 port is set to, my program will change the speed to whatever value you specify on the command line when you run it. MKIV clusters seem to only work at 10400 baud. CCMs only work at 9600.
17 is the address of the cluster.
204 is the first location in the cluster's EEPROM to read and 6 is the number of locations to read (so it would read locations 204, 205, 206, 207, 208 and 209).
If you want to dump the whole EEPROM to a file, you'd specify "0 2048" instead of "204 6".
"204 6" just limits you to the area where the SKC is stored for most MKIV VDO Immo3 clusters.
If you run the program and don't give it any command line parameters, it'll print out some basic help:
Code:
kw1281test.exe
Usage: KW1281Test PORT BAUD ADDRESS COMMAND [args]
       PORT    = COM1|COM2|etc.
       BAUD    = 10400|9600|etc.
       ADDRESS = The controller address, e.g. 17 (cluster), 46 (CCM), 56 (radio)
       COMMAND = ReadIdent
                 ReadSoftwareVersion
                 ReadEeprom ADDRESS
                            ADDRESS = Address in decimal (e.g. 4361) or hex (e.g. $1109)
                 WriteEeprom ADDRESS VALUE
                             VALUE   = Value in decimal (e.g. 138) or hex (e.g. $8A)
                 DumpEeprom START LENGTH
                            START  = Start address in decimal (e.g. 0) or hex (e.g. $0)
                            LENGTH = Number of bytes in decimal (e.g. 2048) or hex (e.g. $800)
                 LoadEeprom START FILENAME
                            FILENAME = Name of file containing binary data to load into EEPROM
                 DumpMem START LENGTH
                         START  = Start address in decimal (e.g. 8192) or hex (e.g. $2000)
                         LENGTH = Number of bytes in decimal (e.g. 65536) or hex (e.g. $10000)
                 MapEeprom
                 Reset
                 DelcoVWPremium5SafeCode
KrashDH
Washington
2002 Golf
kw1281test.exe
COMMAND = ReadIdent
ReadSoftwareVersion
ReadEeprom ADDRESS
MapEeprom
Reset
Ok that makes more sense...what about the "204 6"...is that space supposed to be in there? Edit, looks like you answered that up above
Sorry, trying to collect all the information I can before I have to go out in the rain and do this, I'm going to lose internet service in my driveway
KrashDH
Washington
2002 Golf
Add another person to the list that successfully ran this program.
2002 VW Golf
Key-USB Dual K Ross-Tech Cable
Converted cable to a VCP (virtual COM port)
To convert the hexadecimal value to decimal: https://decimaltobinary.pro/_hexadecimal
One thing to note, let's say your dump looks like this:
Code:
2D 10 2D 10 2D 10
You would enter this from hex--->dec per the website as:
HEX: 102D.....that should give a decimal of 4141
So your SKC, for example, would be 04141
I tested this out on Instrument-17 in VCDS.
You go to the Login-11 button once you're in the controller. It will ask you for the 5 digit code.
When you select "Do It", if you watch your cluster while you click, the Immobilizer symbol (car with a little key) should light up ( if the SKC works). When you exit out of that controller, the light will go off on the cluster.
I tried a random SKC and got no immobilizer symbol on the cluster when I clicked "Do It"
I want to thank @gmenounos for all the hard work and support making this happen for those that want to use it. There's a lot of valuable information that can come out of all of this!
I really hope someday after I finish my schooling that I can understand more of what's going on and even give it a try to write programs like this in the future!!
wonneber
Monroe, NY, USA
If anyone needs it the calculator in Windows 10 has a programmer setting that displays a number in hex, decimal, oct, and bin.
I've used it for the binary option.
KrashDH
Washington
2002 Golf
That's cool I didn't even think to check that out.
I need to update my tech game.
But I did just buy a new laptop and am upgrading new parts with newer better parts haha. I have moditis in all aspects of life
Nuje
Same thing with the built-in calculator app in macOS. Just discovered that feature a couple days ago - definitely quicker and easier when converting multiple values, compared with having to go out to a website.
Thanks again to gmenounos for all the work on this; I just played around with it quickly once I got my SKC (had to use VAG-COMMANDER to do so with that bizarro Bosch / Motometer RB8 cluster), but for doing quick-hit edits and look-ups....very cool!!
KrashDH
Washington
2002 Golf
Want to verify that I was able to successfully re-program my original 2 keys (fob, valet) and one new flip fob with the SKC I pulled from this program. Absolutely awesome. Now my old OE key fob is my backup and the new crisp version is my main squeeze!
ekincaid
North Carolina
03 Golf TDI
Just tried this on my 03 Golf. Got to admit, I really didn't understand much of what you were talking about. But decided what the hell.
Bought this same cable from Amazon.
I just received my $17 generic USB->KKL cable and can confirm that it works with the this software to dump the cluster EEPROM to a file: https://www.amazon.com/gp/product/B00K6498D0
Did some reading here...
Wanted to accomplish three things
1.) Windows by Remote
2.) Trunk unlock with doors
3.) Unlock Doors with Key removal
Put me a list together in case I screwed something up. Everything worked great! :D Thought I would attach the file I used in case it is useful for someone else. Thanks alot!
kw1281 Guide
Nuje
That's a great little summary sheet you put together, ekincaid!
Helpful Dropbox tip: If you change the end of the Dropbox URL from dl=0 to raw=1, you get a direct link instead of all of that Dropbox crap.
(The "raw=1" thing also works for pasting / linking Dropbox photo or image links, using the INSERT IMAGE button on the toolbar here.)
So, kw1281 Guide with raw=1 (url: https://www.dropbox.com/s/2n5khdafwibu6ou/kw1281.pdf?raw=1) opens as a .pdf right in the browser.
ekincaid
North Carolina
03 Golf TDI
Nice Tip! I made the edit...
ekincaid
North Carolina
03 Golf TDI
Hey @Nuje. I do owe you a thankyou. I was really lost about what was going on with the binary numbers until I run into the chart you converted to English and an explanation you made. Things started clicking for me then with what @gmenounos was saying above. This little program is pretty sweet. I decided to post the spreadsheet so if anyone wanted to use it. Definitely easier if you want to edit anything.
kw1281 Guide in Excel
KrashDH
Washington
2002 Golf
As a heads up, the "...multiply 2nd value by 256 and add to first value..." instruction to convert the hex code did not work for me. I had to enter my hex values into an online converter to pull my SKC. So it might be worth linking a calculator on your spreadsheet. Many available online
ekincaid
North Carolina
03 Golf TDI
I'll add that. What was your second value that didn't work? Was it a whole number such as 10 instead of like 0A? A hex of 10 would convert to 16 in decimal. Just want to make it as simple to follow as possible.
ekincaid
North Carolina
03 Golf TDI
I think I may have found a error in my calculation of the SKC. I believe both values may have to be converted to decimal from hex first. @gmenounos Can you confirm this?
Nuje
Glad it helped you out. 👍
For anyone else who wants my "understands just enough hex / binary to be dangerous to himself" explanation of working with that linked summary sheet from ekincaid, there's this post of mine from the "Additional CCM coding" thread.
Nuje
Probably the better way to get the SKC is to stay in a hex calculator (the built-in calculator app in both Windows10 and macOS have a "programmer" display where you can work in base16 = hex mode).
So, in one of my clusters: the three pairs bytes starting at 204 (0xCC in hex) are D3 1F D3 1F D3 1F.
Decimal 256 = 0x100 (hex)
So in a hex calculator, simply enter 1F*100+D3 = 0x1FD3 = 8147
This was confirmed by what I got out of VAG-TACHO.
And in case you didn't notice the pattern there, you can actually skip the whole calculator thing: Just flip the two bytes (D3 1F becomes 1FD3) and enter that as a hex number into a HEX2DEC converter (=HEX2DEC(cell) in Excel does the trick, too) and convert to decimal. Done and done! 😃
Mac example:
(Under VIEW menu, choose PROGRAMMER to get this calculator layout):
