SilverSquirrel
Thanks. Are the special active rears a monotube or twintube for this car?
Rears for now. Fronts seem ok. Plus more of a pita.
Thanks Wilkins, for the reply. I have been down the Bilstein rabbit hole and back, with my 06 audi A3 3.2 awd. Wifes car goes on family road trips, commutes, and all of that. Need comfy. Just ordered the special actives and a whole pile of fluids and filters for the tdi sportwagen.I ran Bilsteins + Tiggy springs on the back of my GSW for nearly a year before gearing up to install the fronts. I thought they were a nice improvement over stock, got rid of any real need for a rear sway bar. I would not call the rear Bilsteins harsh on the mk6 Wagon. With a stock front there was some dive and pitching, only noticeable if you knew it was there.
My Bilsteins fronts are definitely firm and hit hard at low speed over frost cracks but that might be a result of the S3 bushings and heavy duty strut mounts I put in when I changed the struts. If I have a reason to pull the front bearings off again I will probably swap out the strut mounts for stock. Corners really nicely though and apart from the thump over abrupt bumps they are generally compliant and I have no complaints.
Thanks. Ordered from idparts.Probably OK to do Special Actives in the rear only, but it would be much better to replace all 4. Of course you could replace the fronts later.
Too bad for me you guys are on the wrong side of Boston.. it would be much too tempting to bring the tdi in and keep my fingernails cleanWell, we're close to you.![]()
Silversquirrel my understanding is that Bilstein revised the valving in the MK V/ VI B6 shocks after a couple of years to increase compliance. Mine are firm but not harsh except for the crash at low speeds on expansion crack type irregularities. On old lumpy roads without cracks the ride is quite compliant. I’m blaming the upper mounts for now and will have to see what happens when it gets cold, really cold!! I doubt the control arm bushings affect the ride very much, they didn’t when I installed them in my MK IVThe MKV application. Big mistake. Horrible bucking ride, harsh on the bumps.
Oh, and I have the S3 or RS3 whichever is the solid rubber one, control arm bushings. Absolutely great.
Had 034 upper strut mounts at one point. Another warm climate mod. great around here in the summer, but bone rattlers in cold weather. I dont remember if they were with the konis or the Bilsteins. Now on OEM TT MK2 mounts. perfect year round.
What was your impression of the yellows vs. special actives?Koni brought us three 3 series BMWs in the summer: One with stock suspension, one with Special Actives, one with Koni Yellows. The back to back driving was enlightening. BMW stock suspension is both harsh and floaty, and transmits the hardness of the run-flat tires. Special Actives took all that away. They're going in my 335d in the Spring.
A stiffer Rsb will make cornering seem flatter, but ride quality suffers on bad roads. Also, as posted earlier in this long thread Fsds dont like to be lowered, Due to the bump stops confusing the special valve that controls damping. I am assumins same with the special actives. What springs?Is there much difference between the FSD and Special actives?
I have theFSD's along with an h&r rear sway bar on my 2015 passat.
Handles great but at low speeds on the unmaintained cali roads it can be stiff.
The part numbers you see for Special Actives are for MKIV (all), MKV and VI, including Sedan (IRS) and Sportwagen, and MKVII (all). No wagon-specific rears, no rears for beam axle MKVI Jetta Sedan or Beetle. So it's pretty simple. No weight range variation. I don't know of any aftermarket damper maker who does that. If your A3 is the '06 in your signature, you'd get the ones or MKV/VI.Im noticing that the koni special actives for mkv amd mk6 have several part numbers availabe, in addition to the sportwagen application from idparts. This would be for different weight ranges.
Tiguan, audi A3, golf, and others. Might be worth lookin into for my A3. The sportwagen app might be too soft for the A3Q
And it is FANTASTIC:Stoked to see this thread alive and well. My wallet is wincing, but my '03 Golf has gone a long time without any significant expenditure . . . I've got the suplex lift springs + Koni Active Specials inbound for all 4 corners to replace my broken springs and essentially trashed OEM mk4 suspension (204k miles).
A year ago I tackled ball joints, sway bar and lower control arm TT bushings, so fingers crossed I come out of the shop standing a whole heck of a lot taller and handling like a totally different car!
