This car has been lots of fun. one suprise after another. I do enjoy the challenges, and am thankful to be blessed with good friends.
Last Wednesday 5/11/11 I had been noticing some extra vibrations when accelerating, and harder shudders upon shutdown. I figured something was up with my dogbone but hadn't had a chance to investigate. after leaving my sons Piano practice, not 500 yards down the road my coolant temp light beeps & flashes at me. I quickly pull over and check the level.. its empty in the bottle.. yippee!!
I carefully nurse the car around the corner to the nearest walgreens and purchase two gallons of Distilled water to nurse the car home on as I noticed a slow leak coming from the passenger front area of the car.
after a couple of stops for refilling, I made it home and tore into it to try to figure out what happened. with the help of a good friend/customer of mine, we got the entire nose taken apart to find a nice hole cut in the small hose that goes from the coolant bottle to the metal pipe under the IP.
we also found the busted dogbone mount..
Broken Dogbone, worn out rubber donut is root cause. allowed too much movement, and it broke the casting.
We stopped at that point and this customer tells me that he has an extra car that I can borrow until I can get mine fixed. I am thinking awesome! I don't have to worry about turning my wifes life upside down for a weekend until parts get here.
we ride together an hour back to his house where he provides me with a 2009 Jetta Sportwagen TDI 6M with 6300 miles on it.. WOW. he rarely drives it and was adamant about letting me take it, so I did..
such a nice car with the pano roof.
fast forward 400 miles until monday evening when the correct hose arrives from impex on the big brown truck, and my bro in law & I commence putting it back together.
here is a shot of the new hose, routed and ziptied properly, back in all of its holders, no longer getting into the fans.. oopsie!
It only took a little over an hour to get the car reassembled completely. I noticed less vibrations when taking off in 1st, and no more coolant leaks. so thats a good deal!
