Growler
Got Soot Vendor
- Joined
- Nov 24, 2003
- Location
- Millersport, Ohio
- TDI
- Schmutz, 2015 Golf Sportwagen DSG & Schnurren, 2001 Golf GL 2 door 5M
11/4/11
10/23/10
10/23/11
The Basics:
Exterior:
Engine/Transmission:
Interior:
Wheels & Suspension:
Body Condition:
Issues:
10/23/10
10/23/11
The Basics:
- 2003 Jetta Wagon
- WVW Germany built VIN
- Reflex SIlver
- 5 Speed.
- ~148k miles
- Power windows, mirrors
- Black cloth interior, non heated seats.
Exterior:
- GTI Nose Swap 10/23/11 (Happy First Birthday!)
- Depo Smoked E-Code HeadLights w/fogs, LED City lights.
- Back, rear and rear doors tinted 20% Llumar (DARK!)
- Front doors Tinted like 35% (too dark)
- Factory VW Steel Skidplate
- LED turn lights on front fenders
- Rear Fog light.
- Front Aero Wipers
- Front Winter Cover Set
- Aspherical Mirrors
- Rubstrips are painted with black textured truck bed paint
- Short aluminum tipped antenna
- Class 1 trailer hitch.
- TT lift pads
- Brand new complete T4 .216 Injectors - Installed @ 145K (have stock injectors too)
- Malone Stage 3 Custom tune(17.5 PSI with Dynamic idle control, and 1050 RPM permanent idle) (installed on 9/3/11)
- Rocket Chip Stage 3+ (Updated for T4s on 5/17/11)
- South Bend Stage 3 Clutch with 17# Flywheel - Installed @ 145K
- Wavetrac LSD - Installed @ 145K
- 3.16 Final Drive - Installed @ 145K
- CAT 2 Micron Fuel Filter
- Timing belt was changed @ 95K miles w/IDparts TBelt Kit (Replpaced at 176k on 9/30/12 full Boraparts Kit)
- Original Green Dieselgeek Racepipe
- No EGR Cooler
- OMI
- 2.5" Whitbread Catless Downpipe (2/26/11 153k miles) to 3" catback exhaust with resonator and mufflerectomy installed (5/18/11 158k miles)
- Dawes Device - Installed @ 37K (removed @ Malone Tune)
- DG 5 speed short shifter - Installed @ 145K (removed in 2013)
- Old Navy Oil cap
- Dynaflow CCV
- Frostheater
- 10mm rebuilt IP installed at 154k miles to solve hard starting issues.
- 92*C MK2 hotter Thermostat (163,700 miles 11/24/11)
Interior:
- Never Smoked in
- 2004+ Cupholder center console
- Audi MK1 TT pedals w/Beetle S Dead Pedal.
- Aluminum Trim Set w/ in Dash Cup holders.
- Full Sized Glove Box
- McNally A pillar Pod w/EGT/Boost Gauge (0-30psi), EGT Probe relocated between the two RRs in Garrett to read properly. (2/26/11 153k miles)
- Euroswitch
- Monster Mats (Front & Rear)
- Armrest with broken lid hinge (SHOCKING, I know)
- Sunglass holder where driver side OS handle goes
- 15" Avus 2 wheels with Bridgestone Potenza tires
- 16" newbeetle alloys with Snow tires
- Koni FSD shocks in Front, (replaced with Sachs shocks in the back 5/16/14/199k miles) VR6 Front springs, Wagon rear springs will replace the coilovers
- Audi TT front control arm bushings to be installed
- Rear Rotors and Pads Replaced @ 145K
- 337/GLI Front Brake kit (off a GLI with 35K miles) ( New Rotor/Pads) (Not Installed, may be for sale, I like my 15s...)
Body Condition:
- 2002 GTI 1.8t Nose with DEPO Joey modded Headlights/Foglights
- A couple dings on rear Driver’s side wheel Arch.
- Scratches on rear passenger side wheel Arch.
- Tailgate has scratches under license plate holder and there is a small pea sized ding.
Issues:
- Car needs a new front wheel bearing holder to replace the cross threaded/almost stripped carrier bolt.
- will be replacing the control arm bushings, and ball joints and tie rod ends soon
- Front Driver Seat is showing some wear (7 of 10), one of the arm rest hinges sheared off, though, it most likely can be fixed with JB Weld.
- V-tex cover piece on steering column is missing.
- rear brake caliper sticks occasionally replaced with new Calipers, pads & rotors 6/2/14 200,320 miles
