secretreeve
so i noticed today a quite aggressive knocking. its loud. i mean not overly but it can be easily heard. it sounds like its from the centran engine, or the back of the engine around the middle of it.
its fast, speed dependant but at 60/70 its VERY fast, stops when applying the brakes, accelerating or turning. present when maintaining a steady speed/coasting with clutch pedal down.
theres a secondary knocking, it'll knock once when you accelerate, and again when slowing, like something moving back and forward depending on if your speeding up/slowing down, might be related to above knocking.
im hoping this is going to be a simple fix, however the car also has torque steer, pulls right when accelerating, left when letting off the clutch. more predominant at higher speed, 50+ slightly noticeable at lower speeds. might be related to previous mentioned knocking sounds.
any ideas on where and what i should be looking at to narrow these down?
