farmboy12357
Why won't both of my key fobs work for keyless entry? One of them works and when I try to program a second one, it will activate but then the first key fob will quit working. This isn't normal is it?
No Kessy in a North American 2003 Jetta.VCDS will not lear key like KessyKey
they can be add like a typical KEy , but they will not work like Proxy - Kessy key
How are you programming the two fobs?
Put another way, if using VCDS, are you setting the number of fobs to "0" first?
Yeah, sometimes the training method doesn't seem to work... at least for me... and the only solution I've found is to code them from scratch with VCDS.I put one fob in the ignition and turn key ON engine OFF, and shut the door. I then insert the spare into the door and hold it in the lock position for 10 sec and then push one of the buttons of the fob and within 2 sec push the same button again. I believe that was on a youtube video. Not using VCDS, also where do I buy one of those? I see a lot of options but I don't know which one are trustworthy. Thanks!
Jared
