2000 Beetle TDI
Normally when the key is turned off and the radio is on it will remain on until the key is removed from the ignition switch.
Now it stays on and will only turn off by using the button on the radio.
Also at the same time this happened the key fob stopped working.
I may have pushed buttons on the fob with it in the switch (off) with the radio on, did this sequence change system functions or was it a coincidence ?
I am replacing the fob batteries for giggles.
I have vagcom so if there is a magic formula to fix this I need the keystroke walkthrough.
