holeintheice
Any one know how or ever heard of using the key fob to lock the vehicle while running? Is there any way to program BCM or module for RKE? Live in MN, gets old removing the little plastic key hole cover. Thanks, Tom.
Yes. I do not have. Saw a purchase price around $949. Unless someone kn9w where for cheaper. I own a small repair shop, I do not think it would be worth buying only a couple time use.
Is there a specific coding pertaining to the fob working once vehicle is on?
Curious if you know the coding for a Touareg - if fob can be enabled while engine running, My 2012 Jetta TDI is coded that way without issue (Carista app does it) - just can't find it for Touareg (2016)On my passat there is an option under 09, for somthing allow Terminal 15 for lock in coding.
I'll take a look to see if i did for my ma's touareg.
I've looked for it, it's not a setting for the BCM for the Touaregs unfortunately.Curious if you know the coding for a Touareg - if fob can be enabled while engine running, My 2012 Jetta TDI is coded that way without issue (Carista app does it) - just can't find it for Touareg (2016)
