Unfortunately, the side ‘cavity’ doesn’t work. It will let you open up the key slightly, but it closes back as soon as you let go.
I don’t have digital cam, so I have to rely on the DZLKopf’s picture.
My 2001 doesn’t have the notch the lower green arrow is pointing, but has the lip the upper one is pointing. As DZLKopf’s, the lip is the only thing holding the two halves together. I used the smallest screwdriver to pry up the lip while pulling. - Jin
[ May 15, 2001: Message edited by: choij1 ]
