Alberta
Spiderweb cracking on lifters after timing belt teeth stripped
This is a $500 , 00' Jetta I just bought . It's my first vw , I'm an avid gearhead and knew what I was getting into
2000 Jetta Alh 5 speed on new winter tires and has 2.5" straight pipe 379,000 kms
Should I go pull a block with head $200 or just a head for $50 and buy head gasket and bolts for another $100 ? Should I even risk a head job because rods could also be bent ?
Or should I pull the engine and replace it from one of the many in the 3 junkyards to choose from here in Calgary ab
