NickBeek
Recall completed. I'm just waiting for them to wash and vacuum my car now.
Got our recall done with no issues. Really surprised that all they did was put little rubber "clamps" around the lines and they weren't all "tied" together like on most diesels with several fuel lines.Just got our letter of recall on ours too. Got to get the service done also and hope I don't have to strangle the bozos!
This is response #17 in the book of Typical VW Dealer Responses.They repeated themselves, we went back and forth a few more times before the service manager was consulted, and he finally admitted that there had been a "misunderstanding", he had read his instructions wrong and to bring it back in. After they replaced the line as the letter stated that they would, the service manager admitted that there were several other TDIs out there which they had done wrong as well.
Your point is well made: there is no 'option', the line is to be replaced.Fm > Wafinator
I read them the recall letter and noted that nowhere does it say that the dealer is to make any kind of determination, the line is to be replaced, plain and simple. They repeated themselves, we went back and forth a few more times before the service manager was consulted, and he finally admitted that there had been a "misunderstanding", he had read his instructions wrong and to bring it back in.
I got two recall notices, one which indicated a #2 fuel line replacement and 4 dampeners, and the second which stated that only dampeners were needed. My dealer did not replace the #2 fuel line, and the service rep indicated they double-checked with VW for my VIN.When I took my 2011 in they initially only did the dampers. Later when I got home I re-read the recall letter which clearly states "the #2 fuel line will also be replaced". I immediately called the dealer and questioned why it hadn't been done, and they said it was inspected and was fine. I read them the recall letter and noted that nowhere does it say that the dealer is to make any kind of determination, the line is to be replaced, plain and simple. They repeated themselves, we went back and forth a few more times before the service manager was consulted, and he finally admitted that there had been a "misunderstanding", he had read his instructions wrong and to bring it back in. After they replaced the line as the letter stated that they would, the service manager admitted that there were several other TDIs out there which they had done wrong as well.
I've read some other accounts where owners mention that only the dampers were installed and was wondering if anyone else has called their dealer out on that?
..or VW changes their mind, and sends a second notice with different recall instructions, like they did with me.Your point is well made: there is no 'option', the line is to be replaced.
I suggest checking your work order, to determine if it was listed to be done. If it is, then they got $ credit for the work -- though it was not done.
I'm also confused, but I did get two notices from VW, and only one stipulated the #2 line replacement. VW obviously has issues in handling the recall notifications correctly.Good Morning Tim:
I'm just confused--how does VW 'change their mind', when there is an official document stipulating which vehicles are to be addressed. Which for the dampeners, and/or which ones are to have the #2 line replaced.
The change must come from NHTSA. With that in mind, I have a problem with this picture as being presented by the dealership.
In my opinion, you should be correct. However, VW calls them dampeners as in devices that dampen. It is confusing, but it is what it is. What is important is that they are little rubber looking things that clamp onto the fuel lines and they add mass to the fuel lines to change the resonant frequency of the fuel lines to a frequency that is not present in the regen process and they damp (muffle) vibrations. What they are called seems to vary depending on who is naming them. The name is not as important as the function. Nobody is trying to make the fuel lines wet (as in dampen), but another usage of the word dampen is to dampen vibrations. Hence, the term dampeners. It is unusual, but it is not entirely incorrect.I'm confused too, what the heck are "dampeners"? Guys standing around with spray bottles?
One damps vibration with a damper. You dampen things with water!
LOL
some words have more than one meaning...I'm confused too, what the heck are "dampeners"? Guys standing around with spray bottles?
LOL
I just got mine done yesterday. I received fuel line vibration frequency modifiers only... Dampeners, dampers... Its all so confusing...The #2 fuel line is not supposed to be replaced on every vehicle.
There are different criteria's to the recall. If you're vehicle doesn't fall under the correct criteria, you're not getting a #2 fuel line replaced. FYI, most vehicles are under the criteria to only receive fuel line dampeners! I've only seen a handful of line replacements on probably 100 cars so far.
Not ALL of the vehicles require a fuel line replacement. And not all of the letters state the fuel line WILL be replaced.
I just checked the campaign information and there are two different criteria that apply to the vehicles/
Criteria 01 says to replace the fuel line.
Criteria 02 says to install the fuel line dampers.
All vehicles should have criteria 02. SOME vehicles will have criteria 01 and 02. But not all vehicles will have criteria 01.
When the service advisor enters your VIN into the Vw database, it should tell them which critera apply to your car.
Got the recall letter, had mine done on Friday. 20 minutes, in/out and I probably made it longer than it needed to be because I wanted to see what was being done.Funny. I went to dictionary.com to look up damper and dampener. On the right side of the page guess what shows up? An ad for a 2012 Jetta.
When the service adviser enters your VIN into the VW database, it should tell them which criteria apply to your car.
