beowulf_lives
- Joined
- Nov 14, 2024
- Location
- Seattle, WA USA
- TDI
- 2006 Jetta MK5 BRM engine Auto transmission 290K miles
Hi all,
The motor on my 06 Jetta TDI quit today while driving. I would like some guidance on how to troubleshoot.
My father was driving it and I came over and we rolled it into a parking lot and left it. He said it just died. It's been very hot here.
I was hoping once the motor cooled down it would start. We came back 4 hours later and the motor will turn over but I'm not hearing the fuel pump prime. As you can tell I have VAGCOM but I'm not that familiar with it and only took a full reading, no sensor checks yet.
In reading other posts they mention if the J17 fuel pump relay has failed there should be a code. There isn't one. However last year when my crank sensor was going out it also didn't throw any codes either. That relay is probably original.
The crank sensor was replaced 12 months ago as was the fuel pump (OEM). I do all my own work. I also fixed the cut wiring on the MAF sensor and (poorly) spliced in a new glow plug harness. Fuel filter has been replaced every 5k - 10k miles. I think it was last done maybe 3 or 4 months ago. Vehicle averages a consistent 39 - 41 mpg. It's due to have the timing belt replaced, which would be a good time to replace the cam sensor that's listed below. The camshaft is worn and I can hear a bit of a subsonic WOOF from the exhaust. I believe the EGR and MAF codes are related based on other forum posts. My assumption is these aren't the source of the no start problems, I'm just including them for thoroughness.
The vehicle will be towed back to my home tomorrow and I'll take a closer look.
Code:
Monday,25,August,2025,21:18:23:50136
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.1.2 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250604 DS365.0
www.Ross-Tech.com
VIN: 3VWST81K86M724309 License Plate:
Mileage: 483750km-300588mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST81K86M724309 Mileage: 483750km-300588miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2989693
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 649673AA225782AA0B1-8030
VINID: 0E69E390805B2067470840C02414C6B012
6 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 476341 km
Time Indication: 0
Date: 2000.00.00
Time: 01:53:46
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001000
Temperature: 23.4°C
Bin. Bits: 00110000
001026 - EGR System
P0402 - 000 - Excessive Flow - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 476341 km
Time Indication: 0
Date: 2000.00.00
Time: 01:54:51
Freeze Frame:
RPM: 1659 /min
Speed: 64.0 km/h
Load: 20.0 %
Duty Cycle: 100.6 %
Duty Cycle: 95.1 %
Mass Air / Rev.: 275.0 mg/str
Mass Air / Rev.: 0.0 mg/str
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 476351 km
Time Indication: 0
Date: 2000.00.00
Time: 02:06:56
Freeze Frame:
RPM: 1932 /min
Speed: 91.0 km/h
Temperature: 31.5°C
Absolute Pres.: 1203.6 mbar
Mass Flow: 0.00 g/s
(no units): 2.59
Temperature: 79.2°C
009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
P2414 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 478758 km
Time Indication: 0
Date: 2000.00.00
Time: 02:51:32
Freeze Frame:
RPM: 2415 /min
Speed: 112.0 km/h
Mass Flow: 1.42 g/s
Temperature: 36.9°C
Absolute Pres.: 969.0 mbar
Voltage: 1.095 V
(no units): 0.0
001649 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 482986 km
Time Indication: 0
Date: 2000.00.00
Time: 04:18:31
Freeze Frame:
RPM: 777 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.30 V
Bin. Bits: 00001011
Temperature: 27.0°C
Bin. Bits: 10110000
012296 - Camshaft Position Sensor (G40)
P3008 - 000 - Signal Out of Range
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 483752 km
Time Indication: 0
Date: 2000.00.00
Time: 06:33:08
Freeze Frame:
RPM: 210 /min
Speed: 0.0 km/h
Load: 100.0 %
Voltage: 10.18 V
Bin. Bits: 00001011
Idle Stabilization: 0.0°KW
(no units): 35.0
Readiness: 1 3 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 070 0913
Revision: 04507000 Serial number: 00000510050159
Coding: 0000020
VCID: 186E175AAE9F964A579-804C
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 40DE9F3A968FFE8ACF9-8014
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DL
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 71B80AFEEDA52702707-8024
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000205599
Coding: 14018E234004180000140000001400000008730B5C
Shop #: WSC 23071 444 66570
VCID: 2A0ADD9200F314DAF1D-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00063445
Shop #: WSC 23071
7 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 483645 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
ON
01505 - Bulb for Blinkers; Rear Right (M8)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 483646 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
ON
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 476341 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 34
Reset counter: 13
Mileage: 476481 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 26
Reset counter: 0
Mileage: 476481 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Reset counter: 228
Mileage: 476368 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 221
Reset counter: 13
Mileage: 476585 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E2040761
VCID: 2B04D8960F090DD20AB-807E
3 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 77
Mileage: 33835 km
Time Indication: 0
Date: 2000.00.00
Time: 07:02:47
02788 - Internal Communications Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Reset counter: 13
Mileage: 476341 km
Time Indication: 0
Date: 2000.00.00
Time: 07:07:42
Freeze Frame:
Bin. Bits: 00000010
Bin. Bits: 00000000
01304 - Radio
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 62
Mileage: 476341 km
Time Indication: 0
Date: 2000.00.00
Time: 06:41:49
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 38 AIRBAG VW8R 032 6800
Revision: 02032000 Serial number: 0038FD0285T/
Coding: 0013112
VCID: 3928F2DEF555AF42887-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0C0E7568N
Subsystem 3 - Serial number: 6342MSME0C2444053
Subsystem 4 - Serial number: 6351HSME085C0C61B
Subsystem 5 - Serial number: 6361HSME085C231BA
Subsystem 6 - Serial number: 63727SME08315A760
Subsystem 7 - Serial number: 63827SME083706780
1 Fault Found:
01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
014 - Defective - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78AE37DA8EDF764AB79-802C
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023203
Shop #: WSC 23071 067 57207
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A0285EB
Coding: 3F3F0B60071002
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Reset counter: 228
Mileage: 476341 km
Time Indication: 0
Date: 2000.00.00
Time: 06:41:53
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 3632F9E2C44B403A655-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323AC5F228235C1A49D-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74B603EA92B7122A9B1-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372CF4E6C341B9327E3-8062
3 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 3138CAFE2D256702307-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D00D68E311D03E214F-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:14, VBatt start/end: 12.1V/12.1V)-----------
------------------------------24 Faults Found------------------------------
