Jetta MkV "Easter Eggs"....hidden tricks!
Guttboy
Colorado at 7500'
Jetta MkV 2005.5 Platinum Gray/Gray Leather Pk2
Jetta MkV \"Easter Eggs\"....hidden tricks!
Ok everyone....
I have heard there are many things that can be done on the older jettas such as getting speed readings from the climatronic and others that are not written in the manual.
SOOOOOO....whats out there for our MkV's!!!!????!!!!!
Post the results here!!!! This should be stuff that the Non VAG COM members can use. We should use the OBD forum for VAG stuff.
1) If you push the AUTO button on the Climatronic for 3 seconds...the passenger temp will be the same as the driver temp until the passenger changes it. (found on VW VORTEX).
Keep adding to the list!
saboteur
Brisbane, Australia
2008 Golf Pacific 2.0 TDI
Re: Jetta MkV \"Easter Eggs\"....hidden tricks!
This is probably in the manual, but when you are going to wash your car, turn the ignition off then pull down on the washer stalk and the wipers will go to the up position so you can clean the windscreen.
Guttboy
Colorado at 7500'
Saboteur,
Thanks I read this but have not tried it...will do so today!
DavidG
Southern NH
None now
That one is in the manual. It's used to change the wiper blades.
aj164
CS, TX
'06 Jetta DSG pkg2
There is a keyhole under the rear trunklid so yous can open the trunk with the key. It took me two months before I noticed it -- thought it was electric only.
Deansel
Central Wisconsin
'06 Jetta w/DSG, pkg1, Blue Graphite
After owning the car for over a month my wife discovered the adjustable center armrest - I guess we need to re-read the owners manual. We have been making little discoveries all along the way, it's part of the fun.
ohiodon
Ohio
06 Jetta TDI DSG package 1
Jetta 06 Hidden tricks!
Ok here’s two:
Tap on the turn signal stalk and the signal indicator will blink three times for switching lanes.
The turn signal clicking sound decreases in volume as the vehicle slows down. Next time you’re on the freeway as you signal to get off and come to a stop (leave the indicator on) the volume decreases. We’ll need to have the radio off to hear the difference.
I’ve had my Jetta for 4 days now :D. Think what I might find in a month…..
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
If you activate the windshield washer while the car is moving, it delays starting the wiper until there's some fluid already sprayed on the window (to minimize dry smearing), it will do 4 swipes, wait a few seconds, then do one more swipe to catch the last dribbles.
If you leave the driver's door open for a few minutes, it switches off the courtesy lights to avoid draining the battery. Just noticed that one today.
If you switch off the engine with the turn signal on in either direction, it will beep at you to let you know, and then it will leave the marker lights on, on the side that you have the turn signal set to.
Psyonic
Fort Worth, Texas
'06 Jetta TDI Manual
I've noticed that if you power off the car with the radio on, the radio will power off, but you can then turn the radio back on without the key in the ignition. Probably not new to anyone else, but I thought it was kinda cool. This is my first VW. :)
ohiodon
Ohio
The radio will stay on for about an hour with no key.
TonyJetta
Tucson, Az
'15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
wiper park
Be careful with the wiper parking for winter/service.
I tried it yesterday, then went for a drive & the wipers wouldn't work for ~5 minutes. I could squirt fluid all day long, they just wouldn't wipe. After the time delay, then everything worked normally.
HTH
Tony
aj164
CS, TX
'06 Jetta DSG pkg2
ohiodon said:
Ok here’s two:
I like the feature, but I also just found a side-effect: If you tap the turn signal, you're going to get 3 flashes whether you want it or not. So if you hit it by accident, there's no way to cancel. I tried hitting it the other direction, but then it flashed 3 times the other way. I tried tapping it a second time, but I ended up with 4 flashes total. :rolleyes:
aj164
CS, TX
'06 Jetta DSG pkg2
dbh said:
If you hold it for 2 blinks and let it go it instantly quits.
Yeah, but then you might as well just give up and let it do the 3 blinks. :cool:
spelchek
QLD. Australia
A5 Golf 2.0l TDI
My thoughts exactly...its a handy feature, but the driver should be able to cancel it by a quick flip in the other direction IMO.
SoaceMunky
Webster, TX
Blue Anthracite Golf IV, 13 miles and counting ;)
i agree, new bmws do this, it gets annoying. but you get used to it...i guess you have to.
the whole concept of taking controll away from the driver, as insignificant, and good-hearted as intended by the engineer is just not pallable to such driving aces as you and i :(
TVguy
Colorado, USA
2006 Jetta TDI DSG, package 1, CWP
Good stuff, but not really "Easter-eggs".
I'm want to find some of the good stuff, like on a certain Fords where you turn the key to on, then activate the left turnsignal, turn the key to off- then honk once within 3 seconds (or some complicated sequence like that) then you activate the Speed Variable Wipers.
spelchek
QLD. Australia
A5 Golf 2.0l TDI
<snob voice>
I prefer to just let my automatic rain sensor wipers and automatic light sensor lights take care of all that tiresome button pressing and switching, I mean really... :rolleyes:
</snob voice>
:D
Phoenix42
Littleton, MA
'08 Mazda3 Hatch
I added this feature to my 00 Golf, not that I use it much, living & working in the 'burbs doesn't give many opertunities for on street parking.
BeetleGo
Cambridge, MA
5-door, 5-speed Golf GLS replaced BeetleGo.
If you leave the glove box door open for 30 seconds and remove 10 lbs. from the rear passenger tire when it's warmer than 73 degrees outside, the horn plays the first few notes of the theme song from 'Grease!' :D
aj164
CS, TX
'06 Jetta DSG pkg2
Funny. Mine played Beethoven's Ninth.
Tarka
Greely, ON
2012 Jetta TDI, Highline, Technology package
I may be wrong on this, but I think I noticed once that if the wipers are set to continuous operation and you come to a stop, they temporarily switch to intermittent mode until you start up again and they revert to continuous operation. Or is something on my 2006 PD broken?
aj164
CS, TX
'06 Jetta DSG pkg2
True. Also, if you're in high speed and come to a stop, they'll drop back to low speed. It's nice, but the auto wipers would be cool. Anyway, TVguy is right -- we haven't found any real "Easter Eggs" yet.
compu_85
Gadget Guy
Springfield VA
... None :S
You and all your Phaeton hand-me-downs :D
You guys have a menu system on your MFA, right, where you can change various parameters for the rest of the car?
-J
WillR
Honey Brook, PA
If you have dual zone climate control, you have to set the temp adj knobs all the way up to High (which turns off automatic) and the electric cabin heater will work. It don't seem to ever come on if you leave it set to auto with any temps except high.
dbh
Alberta, Canada
Jetta, 2006, black
Here's one I stumbled across that's perhaps a bit more Easter Eggie, even though I later found it in the manual - if you have the standard radio like I have press the Scan knob and hold it in. In a little while you'll see a menu of tweaks you can do to customize the radio.
dbh
TVguy
Colorado, USA
There is a (new?) Jetta Pocket Reference on the VW site that explains a number of items that are not in the owner's manual. A lot of it looks like the engineering department's answer to customer complaints. Here is an example:
Cruise Control Stalk
C
ONDITION:
• Cruise control is hard to operate; stalk is blocked by steering wheel
R
EMARKS:
• Cruise control lever is located at the left side just below of turn signal
lever, (circled)
Or one of my favorites:
Front Cupholder
CONDITION:
• Front cupholder cannot hold large drinks
R
EMARKS:
• Cupholder can hold “large” cups, but “jumbo” size does not fit in
These gems and other potential "Easter Eggs" can be found here:
http://www.vw.com/vwcom/content/objects/pdf/service_maint/jetta_pocketguide.pdf
It's a big PDF file (8,326k), so be patient.
Enjoy...​
