Gun-driver
What is the purpose of the “T” in the top of the fuel filter.
I changed my filter and I’m having trouble keeping it from leaking.
I don't think he's talking about the retaining clip. I think he's talking about a large T-shaped cover that is only used in some TDI models.The monkey clip is necessary, yes; it slots in the filter and holds it in place. IDParts has it or you can fashion something from coat-hanger style stock of the appropriate size (it's sort of obvious how it fits and holds it in place)
The seal is made with O-rings, not pressure, but if it backs out it will leak (usually air, which causes all sorts of bizarre hard-starting problems.)
Yes this https://www.idparts.com/fuel-filter-tee-protective-plate-a4-p-2607.htmlI don't think he's talking about the retaining clip. I think he's talking about a large T-shaped cover that is only used in some TDI models.
There is a temperature when all diesel will gel, with or without the thermo-T.I disagree with the claim that the thermostatic-T is essential or even effective.
If the fuel is gelling, the thermo-T will recycle hot fuel back into the filter so the engine will run for 5 or 10 minutes. But when the T opens up to send that hot fuel back to the fuel tank, cold gelled fuel will enter the filter and the engine will die.
Personally, I would prefer that my engine not start at all, than have it run until I'm several miles from home before it dies and the car needs a tow.
Just dump a gallon of gasoline in the tank, it'll work fine.People who think preheated fuel filters do not work have never owned or driven a pre-1989 VAG diesel in the winter.
For me the worry/don't worry cutoff is around -8°F. That's when I start doubling the amount of extra anti-gel additive.ugh, I was more diligent about extra anti-gel additives on the older stuff. My TDIs I only ever worry if it gets down to around 0 F and I know it may stay that way, which is rare here but it happens.
