tdi_guest
- Joined
- Jun 6, 2005
- Location
- Chicago
- TDI
- 2003 VW Jetta GLS Wagon, Reflex Silver - totalled; replaced with 2006 VW Jetta TDI, black pkg#1, DSG
TwoTone, I'm only aware of the TSB 30 07 01 (http://forums.tdiclub.com/showpost.php?p=1917995&postcount=1045) which was for the clutch plate friction material. Would this apply to the DSG? Is there another I should be aware of?
From what I can tell, this TSB seems to be a way VW replaced faulty Sachs flywheels without attributing fault to them. The TSB attributes the fault with the Sachs clutch plates, but in essence it is used to replace the bad Sachs flywheels because the replacement clutch plate from Luk must be matched with a Luk flywheel (see Note on page 4 of the TSB).
