Noticed recently my 2014 Jetta TDI locks my doors after I unlock with the key fob. Anyone else had this problem? It does not happen Iimmediately. Maybe after a couple minutes.
Most likely the driver door latch is bad. Specifically, the microswitch that tells the car that the door is open. If it never sees that signal, it will relock the doors and rearm the alarm. You can check all this data with a suitable scan tool.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
