Jetta 2003
ayllonreyna
San Diego
Don’t know
I change the fuse for the cigarette lighter with yellow fuse the same color on the space 41 but in the chart saids I should put a 15 or blue
What should I do. Same color I took off or blue, like the paper said.
red16vdub
(617) City of CHAMPIONS
03 JSW 5spd
If you’re car’s fuse box manual requires 15amp blue then that’s the obvious choice. In an emergency situation if for some reason your fuse blows, it’s always better to step down in amperage than to go up. In other words, used a 10amp instead of a 20amp or above.
