PickleRick
- Joined
- Nov 29, 2017
- Location
- Greenville sc
- TDI
- 05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress
My only issue with non clocked tdi would be the oil level is now incorrect.
Have you game planned what you will be doing to mount the MAP sensor? I cannot find any pre made adapters that fit our small 35ish mm side to side bolt hole map sensors. Plenty of smaller and larger ones, larger likely mislabeled maf sensor adapters.
The passat uses it mounted on the rear upper charge pipe.
