Sorry for the lack of updates, I've been busy working on the Jeep. Got my intercooler:
It's a factory 2005 Jeep CRD intercooler. Much bigger than the factory TDI intercooler.
Made a stealth race pipe. I used a pipe plug to block off where the EGR pipe exhaust pipe had been. Made it self-tapping by cutting some grooves in it:
Really cleaned out the throttle body:
I did polish it further after that and I port matched the intake as well but didn't take pictures.
I got my adapters from the machine shop:
And with the Jeep flywheel installed:
Engine dropped right in:
Drivers side motor mount (I used a small block Chevy clamshell mount):
Passengers side mount (Used the isolator part of a VW gasser mount):
It looks thin in that picture, but it is 1/4" plate.
I've also got the exhaust done (2 1/2"), the coolant lines connected, and I remote mounted my oil heat exchanger and installed a Zerostart heater. I'll have to get some pictures of that up.
I have to get the P/S lines hooked up and the wiring finished (hopefully tomorrow). But I'm held up after that because I can't get a 2005 CRD radiator. The aftermarket ones listed for a CRD don't actually fit and no wrecker within 600kms of me has one in stock. I guess thats the problem with a vehicle that was only made for 2 years and had a different rad for each year.
It's good to finally be making some good progress - I'm actually hopeing to be able to drive it before Christmas. (I did actually hook up the starter and it turns over really nicely)
