Bellyman
Hi guys,
Hope this won't be too basic of a question but I doubt I'm the first to wonder about this.
I have to do a timing belt / water pump job on a 2004 Jetta TDI. Doesn't look like it'll be a bad job. I think I have assembled everything I'll need to do the job.
Problem is, I have no really good place to do it. I'm stuck with a gravel driveway, fairly level but not quite perfectly level. I hate working on the ground. But I'm kinda stuck without a lot of choices.
How would you support the front end of the car while working on it? I'm a little leary of just sticking the jack stands in the same places as I would if this were a concrete garage floor. (Would I like that!!) I'm about half afraid they'll decide to be less than great about moving around and possibly dumping the car on top of me while I'm under there wrenching.
One thought I had was to use a set of ramps under the front wheels. I have a set that I typically use when doing oil changes and things of that nature. I had wondered if I could pull off the right front wheel, pull off the shrouds that are in the way, put the wheel back on and the ramp underneath before climbing under there to work. I could turn the wheels all the way to the right to try to give me just a bit more room.
Anybody have any ideas on how to do such a basic thing... (step 1)... safely? With or without the ramps? Other support ideas?
It's always this kind of stupid little stuff that gets me. I envy you guys with even the most basic of garages right now. (And no, I don't have a friend closeby with a garage either. Wish I did.)
Thanks for any suggestions.
Brian
Brian
