(J388) LR door no communication
pro51492
Hustisford, WI
2012 Sportwagen TDI 6sp
Problem is on my 12 JSW. Ok so this problem started a few weeks back when I noticed the orange lock light was not illuminating like usual after the doors locked. Checked all the doors and the LR door had no lights and nothing would work. Unplugged the harness from the body and checked for corrosion or leaks and nothing plugged it back in and the lock button would work but no window functions.
Driving to work this week and noticed the orange light was lit looked back and sure enough everything is illuminated and window works this was the case for two days and then nothing again. Now we are at Friday the door is locked but no communication I pull the handle from inside to unlock it and now the car thinks the door is open. So today I pull the door card off verify harness is not shorted pull the door subframe and remove actuator assembly and replace with harness from my parts car window motor and lock actuator. Now still nothing but from what the Erwin manual states is the new module needs to be programmed.
My question is how with no communication. I am no coding expert with VCDS and from what I can tell the long coding is the same between the two. I have my old actuator and window motor dummied up on the old harness so I can swap them but still getting J388 no communication and the car still thinks the door is open.
pro51492
Hustisford, WI
Saturday,24,February,2024,10:32:30:15984
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: 3VWML7AJXCM648307 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72 77
VIN: 3VWML7AJXCM648307 Mileage: 278680km-173163miles
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 D HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 74291 008 00000
VCID: 2F3B0035FB1EAB72869-807A
VINID: 0E69DD70745AA137461080C01CFCC66B9F
No fault code found.
Readiness: 0 0 0 X X
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C49260002880E06E492200042B70000
Shop #: WSC 00066 000 00000
VCID: 7BA3E46573E687D27A1-802E
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 277626 km
Time Indication: 0
Date: 2018.07.13
Time: 16:24:42
Freeze Frame:
Count: 2
Count: 2
Count: 4096
Count: 16390
Count: 44544
Count: 65280
Count: 256
Count: 0
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 277626 km
Time Indication: 0
Date: 2018.07.13
Time: 16:24:32
Freeze Frame:
Count: 0
Count: 2
Count: 4096
Count: 8194
Count: 44544
Count: 65281
Count: 256
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001016
Coding: 0000001002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 005993891A80E40A2F3-8054
2 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Motorsteuergerät - kein Signal/Kommunikation]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 208
Mileage: 277626 km
Date: 2024.02.20
Time: 16:24:32
13701520 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Türsteuergerät hinten links - kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 175
Mileage: 253587 km
Date: 2023.06.29
Time: 16:13:25
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 G HW: 5K0 937 084 G
Component: BCM PQ35 B 011 2048
Revision: BG011001
Coding: 2F380E1F802F3EC4008800817000004441000086535D0560648020200040
Shop #: WSC 09108 003 1048576
VCID: 3635355108449ABAC5F-8062
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 15111 26 0512
Coding: 009795
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 175
Mileage: 278686 km
Time Indication: 0
Date: 2018.07.17
Time: 10:09:54
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA0MTAJ Dataset Number: 1KM003v__B_ 0035
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDB507527FE5BF2169-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00006F7C00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME4372237BZZZW
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME3C151665ZZZX
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME4E461F29ZZZ-
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME30162F29ZZZK
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME560B6728ZZZL
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME4B684028ZZZK
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KIR00036 Dataset Number: 5K0953507BC D005
Coding: 108A140000
Shop #: WSC 00066 000 00185
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72BDC941242CC69A297-8026
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0691378
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 972 CX HW: 5K0 920 972 CX
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
Shop #: WSC 08156 444 105103
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 08498BA932B0DC4A673-805C
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
[Steuergerät für Motor: keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 208
Mileage: 277626 km
Date: 2024.02.20
Time: 16:24:31
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 20101101290114
Coding: 352002
VCID: 38293B6902506CCAD73-806C
6 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 277626 km
Time Indication: 0
Date: 2018.07.13
Time: 16:24:33
01336 - Company Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 3
Reset counter: 255
Mileage: 266841 km
Time Indication: 0
Date: 2018.04.10
Time: 13:09:44
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Reset counter: 215
Mileage: 256175 km
Time Indication: 0
Date: 2018.01.04
Time: 16:40:16
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 189
Mileage: 276183 km
Time Indication: 0
Date: 2018.06.26
Time: 09:03:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 160
Mileage: 253587 km
Time Indication: 0
Date: 2017.11.14
Time: 11:39:12
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 277153 km
Time Indication: 0
Date: 2018.07.03
Time: 09:58:41
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RF2V706
Coding: 0000002
VCID: 7EA5ED716CF492FA5DF-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD1210CFC0E5A917-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660886006
Coding: 010000
VCID: 290FEE2DC9FAC54258D-807C
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0006882822
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE384E5D3A667D21A1-800E
1 Fault Found:
65538 - Local Data Bus
U10BA 00 [00001001] - No Communication
[Front Timeout LIN Sub bus]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 175
Mileage: 278686 km
Date: 2024.02.24
Time: 10:19:02
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 34310F59123888AAFBB-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 208
Mileage: 277626 km
Time Indication: 0
Date: 2018.07.13
Time: 16:41:43
Freeze Frame:
Voltage: 12.50 V
DU
Temperature: 28.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 050B0500
VCID: 6FBBC035379EEB72C69-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0003602219
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE187F9D6A860EA13B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1509
Serial number: 00000005973193
Coding: 000490
1 Fault Found:
68108 - Function Restricted due to Missing Message(s)
[Front CAN MSG]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 208
Mileage: 277626 km
Date: 2024.02.20
Time: 16:24:31
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3220599
Coding: 01000400040007
VCID: 6393BC05EB565F12521-8036
3 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 9
Reset counter: 98
Mileage: 184430 km
Time Indication: 0
Date: 2016.03.02
Time: 11:21:26
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 175
Mileage: 277153 km
Time Indication: 0
Date: 2018.07.03
Time: 10:41:36
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 175
Mileage: 277153 km
Time Indication: 0
Date: 2018.07.03
Time: 10:41:37
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660756059 Dataset Number: 5K0035730E 0001
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BE815DF6EF3324E9-8072
End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.3V)-----------
pro51492
Hustisford, WI
Still trying to resolve this issue. Per the log its seems I am getting a lot of intermittent communication faults. I am wondering if this is possibly a larger wiring or ground issue. Any help is much appreciated. The radio faults are due to the door panel being disconnected at the time of the auto scan.
DrGERTol
NW OH
2011 Golf Variant (JSW) 6MT
@pro51492 --See remarks from Uwe at Ross-Tech on posting VCDS logs in CODE blocks here: https://forums.ross-tech.com/index.php?threads/101/
I think I would start with the CAN bus wiring from the CAN Gateway J533, fitted above the driver footwell, to the right of the steering column. Ensure continuity between J386 T20a/8 and /9 to J533 T20/15 (or/gn) and T20/5 (or/bn), respectively. The wiring diagrams tell us that the Comfort CAN bus has splices/crimps in the dash wiring harness, so make sure you have no sign of moisture here. --g
pro51492
Hustisford, WI
Thank you for the response @DrGERTol. Problem solved the orange lock on the driver front door harness was broken seems it was not getting a good connection, as soon as I put pressure on the plug it recognized the rear door. Changed the lock out and solved the problem. I suppose I should have started up front being as the rear door is a slave module.
